Kycannz Posted October 15, 2008 Posted October 15, 2008 Im sorry if this problem is already solved in another thread but....i cant find any so.....my question is. Im drawing in isometric view and want to change the default drawing angle from 30 degrees to another angle. How do I go about doing this? thanks! Quote
GhostRider Posted October 15, 2008 Posted October 15, 2008 you can rotate the view with ORBIT command or the orbit toolbar has a few options. Not sure if you change the standard angle of a view like shaging SE isometric to say 40 deg.. if that's what your looking to do View command brings up the view manager play with the settings and angles a bit.. Quote
alanjt Posted October 16, 2008 Posted October 16, 2008 just create your own modified isometric views and you can set to them. Quote
ReMark Posted October 16, 2008 Posted October 16, 2008 Are you drawing in a 2D or 3D environment? In 3D you have more flexibility. In 2D your choices are limited. Quote
Kycannz Posted October 20, 2008 Author Posted October 20, 2008 2D and how do i make my own modified isometric view? Quote
ReMark Posted October 20, 2008 Posted October 20, 2008 I can tell you how to get into 2D isometric from the command line. Type Snap, then press Enter. Type for Style then press Enter. Type for Isometric then press Enter. You'll be prompted by AutoCAD for the vertical spacing. Enter your spacing. The cross-hairs are controlled with a key combination of & . As you toggle it the Isoplane will change from Top, to Right then to Left. You cannot change the angle of the isoplane. It's hardwired into AutoCAD. Sorry. BTW...I usually toggle SNAP off (use the F9 key). Quote
Kycannz Posted October 20, 2008 Author Posted October 20, 2008 Right I know how to get into 2D iso view i was just wondering if i could change the default drawing angle from 30 degrees to say....20 or 10 degrees. Quote
ABuckingham Posted October 20, 2008 Posted October 20, 2008 The Iso-snap is essentially a convenient way to work with isometric drawings however you could just as easily use the Polar toggle with the appropriate angles. May I ask what you're trying to do? Angles are not well preserved from orthographic is isometric perspective so if you're looking for a way to draw particular angles in isometric that are not parallel to one of the isometric axes you may need to do some trig. Quote
Kycannz Posted October 20, 2008 Author Posted October 20, 2008 The Iso-snap is essentially a convenient way to work with isometric drawings however you could just as easily use the Polar toggle with the appropriate angles. May I ask what you're trying to do? Angles are not well preserved from orthographic is isometric perspective so if you're looking for a way to draw particular angles in isometric that are not parallel to one of the isometric axes you may need to do some trig. Im trying to draw, lets call it a chair for simplicity's sake, in a isometric view but show it at an angle where the side views are more dominant than the top view. To do so would need a lower angle than the default 30 degrees. Im kinda avoiding doing a 3D model of it but it looks like i may have to do it to get the kind of drawing im looking for. Quote
ABuckingham Posted October 20, 2008 Posted October 20, 2008 Im kinda avoiding doing a 3D model of it but it looks like i may have to do it to get the kind of drawing im looking for. I think you'll find that 3D models are easier then drawing 2D projections once you become accustomed to it. As an aside projections from other angles that are not isometric are often called Oblique Projections. To draw these you'll want to use the polar tracking toggle using whatever angle you're looking for if you're limited to 2D. Quote
Kycannz Posted October 20, 2008 Author Posted October 20, 2008 O I'm sure it will be. Thanks to everyone this was really helpfully. I'm definitely coming back with all my questions. Quote
rkent Posted October 20, 2008 Posted October 20, 2008 You could use dimetric or trimetric projections rather than isometric. Use polar settings for the various angles. Quote
FORDNUT Posted December 6, 2010 Posted December 6, 2010 You can change the cursor angle to draw at different angles aligned with the cursor, BUT it only works in one plane, meaning for you to create isometric views with angles other than 30 degrees, you will have to change the snapang every time you change planes. I use snapang when drawing an object in isometric that does not fall exactly on the 30 degree angle. See images attached. Hope this helps. Pete Quote
Momsy Posted December 2, 2011 Posted December 2, 2011 Wow thanks for the Polar Snap lesson made drawing my Isometrics every so easy. Sucks that you can change the angles on the Isometric Snap, you used to be able to in Autocad 2000. Quote
Tankman Posted December 3, 2011 Posted December 3, 2011 Right I know how to get into 2D iso view i was just wondering if i could change the default drawing angle from 30 degrees to say....20 or 10 degrees. You might like to try this link, http://www.andrew.cmu.edu/course/48-568/2DVideosWEB_files/frame.htm Chapter 40. You can also download the lesson in *.pdf format for reference. Quote
Bill Tillman Posted December 4, 2011 Posted December 4, 2011 It should be noted here that 3D drawing is an artform and as you learn the process you will develop your own style of doing things. There is no right or wrong way as long as you end up with the views and shapes you are after. My method of drawing 3D would make some people croak, but for me it's easy and profficient. Your style will develope as you learn. And we suggest you learn to work with the default and adjust the angle of your views as needed using commands like 3DFORBIT, ORBIT, VIEW, etc... Quote
SLW210 Posted December 5, 2011 Posted December 5, 2011 You do realize this a three year old thread. Quote
