j_spawn_h Posted October 11, 2011 Posted October 11, 2011 Is there any thing I can put in my lisp to keep someone from using it if they copied from my computer to theirs? Quote
Lee Mac Posted October 11, 2011 Posted October 11, 2011 Is there any thing I can put in my lisp to keep someone from using it if they copied from my computer to theirs? Hard-code your AutoCAD serial number (_PKSER) (or some other unique identifier to your computer) into the LISP, then compile the LISP to a VLX to make it uneditable. Quote
pBe Posted October 11, 2011 Posted October 11, 2011 I usually use loginame, but AutoCAD serial number sounds a lot cooler . I'll try that. Tnx Lee Quote
ketxu Posted October 11, 2011 Posted October 11, 2011 Oh.. Somewhere all people use a crac* version, so their _PKSER always is "000-00000000" or "999-99999999", or has same Serial.....(might be OP ^^) Hi, just a joke ^^ I think we should use HDD Serial or sth similar Quote
Lee Mac Posted October 11, 2011 Posted October 11, 2011 Hi, just a joke ^^ I think we should use HDD Serial or sth similar Maybe (virtual serial): (defun HDSerial ( drive / fso drv ser ) (vl-catch-all-apply (function (lambda nil (setq fso (vlax-create-object "Scripting.FileSystemObject") drv (vlax-invoke-method fso 'getdrive drive) ser (vlax-get-property drv 'serialnumber) ) ) ) ) (if drv (vlax-release-object drv)) (if fso (vlax-release-object fso)) ser ) Or, for the manufacturer's Serial number (only works in Vista or 7): (defun HDSerial ( / wmi srv drv ser ) (vl-catch-all-apply (function (lambda ( ) (if (setq wmi (vlax-create-object "WbemScripting.SWbemLocator") srv (vlax-invoke wmi 'connectserver nil nil nil nil nil nil nil nil) drv (vlax-invoke srv 'execquery "Select SerialNumber from Win32_DiskDrive") ) (vlax-for item drv (vlax-for prop (vlax-get item 'Properties_) (if (eq "SERIALNUMBER" (strcase (vlax-get prop 'name))) (setq ser (vl-string-trim " " (vlax-get prop 'value))) ) ) ) ) ) ) ) (if drv (vlax-release-object drv)) (if srv (vlax-release-object srv)) (if wmi (vlax-release-object wmi)) ser ) 1 Quote
ReMark Posted October 11, 2011 Posted October 11, 2011 I thought that most people write lisp routines because they DO want to share them. Now share can mean 1) free or 2) at a cost but don't you want the world beating a path to your door demanding the perfect lisp routine you went through all the trouble to create? Have you ever "borrowed" someone else's lisp routine? Quote
