Is there a way to put the purge and bind at the beginning, then instead of savas is it possible to do a aectoacad. Not changing anything but the bind and purge will be done before aectoacad to the folder location.
Do you know what I mean by use AECTOACAD instead of saveas?
  • Replies 22
  • neekcotrack
    12
  • CAB
    10
  • borgunit
    1
I have not used that command.
http://discussion.autodesk.com/forums/thread.jspa?threadID=465456
You may give it a try.
Ok I got it to work.
(defun c:BindIt (/ LST VANS VDATE VDATESTR VDAY VDIA VDIR VECHO VMONTH VNAME VPREFIX VYEAR X)
 ;;  CAB 10/07/08
 ;; (splitdirs "c:\\123\\456\\789") returns ("c:" "123" "456" "789")
 (defun splitdirs (str / lst pos)
   (while (or (setq pos (vl-string-search "\\" str))
              (setq pos (vl-string-search "/" str))
     (setq lst (cons (substr str 1 pos) lst)
           str (substr str (+ pos 2))
   (if (> (strlen str) 0)
     (setq lst (cons str lst))
   (reverse lst)
 (setq vDia     (getvar "filedia")
       vEcho    (getvar "cmdecho")
       vPrefix  (getvar "dwgprefix")
       vName    (getvar "dwgname")
       vDate    (rtos (getvar "cdate") 2 6)
       vYear    (substr vDate 1 4)
       vMonth   (substr vDate 5 2)
       vDay     (substr vDate 7 2)
       vDateStr (strcat vYear "-" vMonth "-" vDay)
 ;;  remove the last 2 dirs
 (setq lst (reverse (cddr (reverse (splitdirs vPrefix)))))
 (setq vPrefix "")
 (mapcar '(lambda (x) (setq vPrefix (strcat vPrefix x "\\"))) lst)
 (setvar "filedia" 0)
 (setvar "cmdecho" 0)
 (initget "Bound Email")
 (setq vDir (getkword "\nSave file to [Email/Bound] <Bound>: "))
 (cond
   ((or (null vDir) (= "Bound" vAns))
    (setq vDir (strcat vPrefix "Bound"))
    (vl-mkdir vDir)
   (t
    (setq vDir (strcat vPrefix "Email"))
    (vl-mkdir vDir)
 (if (vl-file-directory-p vDir)
     ;;  The following is to create a seperate directory for each date
     (setq vDir (strcat vDir "\\" vDateStr))
     (cond
       ((and (null (vl-file-directory-p vDir))
             (null (vl-mkdir vDir))
        (prompt (strcat "\nError - Could not create Folder: " vDir))
       (t ; folder exist
        ;;(command "_.-exporttoautocad" "F" "2004" "" (strcat vDir "\\" vDateStr "-" vName))
        (command "_.-exporttoautocad" "F" "2004" "" (strcat vDir "\\" vName))
 (setvar "filedia" vDia)
 (setvar "cmdecho" vEcho)
So if you have never used AECTOACAD it is something that building systems has. Like AutoCAD MEP 2009 . It converts 3D objects over to 2D objects so people with just regular CAD can use it.
Thanks again CAB!!!!!!!!!!
