Is there any way to have it go back two folders to save the folder bound or e-mail?
Example: M:\1234\dwgs\electrical and I want it to save the folders in the 1234 folder that would be two folders. You can also think of it as the folder before the dwgs folder to. Thanks in advance for everything.
(defun c:BindIt ( / )
(setq vDia (getvar "filedia")
      vEcho (getvar "cmdecho")
      vPrefix (getvar "dwgprefix")
      vName (getvar "dwgname")
      vDate (rtos (getvar "cdate") 2 6)
      vYear (substr vDate 1 4)
      vMonth (substr vDate 5 2)
      vDay (substr vDate 7 2)
      vDateStr (strcat vYear "-" vMonth "-" vDay)
(setvar "filedia" 0)
(setvar "cmdecho" 0)
(initget 1 "Bind Email")
(setq vAns (getkword "\nSave file to [Email / Bound] <Bound>: "))
(cond
 ((= "Bind" vAns)
  (setq vDir (strcat vPrefix "Bound"))
 ((= "Email" vAns)
  (setq vDir (strcat vPrefix "Email"))
(if (= (vl-file-directory-p vDir) nil)
  (vl-mkdir vDir)
  (vl-mkdir (strcat vDir "\\" vDateStr))
 (if (= (vl-file-directory-p (strcat vDir "\\" vDateStr)) nil)
(command ".saveas" "" (strcat vDir "\\" vDateStr "\\" vName))
(setvar "filedia" vDia)
(setvar "cmdecho" vEcho)
Thanks for any help!!!
  • Replies 22
  • neekcotrack
    12
  • CAB
    10
  • borgunit
    1
This would trim up the path by two folders
;;;Finds the folder name by how many folders up supplied in argument
;;;No error checking for too many folders argument
;;;Example:    (pp_GetFolderNameUp 2)
(defun pp_GetFolderNameUp(sNo /)
 (vl-load-com)
 (setq sPath (pp_StrRev (getvar "dwgprefix")))
 ;Get to folder above
 (repeat sNo
   (setq sPath (substr sPath (+ (vl-string-search "\\" sPath)  3)))
   ) ;repeat
 ;Trim leftover folder name
 (setq sPath (pp_StrRev (substr sPath (+ (vl-string-search "\\" sPath)  1))))
 spath
 ) ;defun
;pp_StrRev: String reverse
(defun pp_StrRev (STR)
 (vl-list->string(reverse(vl-string->list STR)))
Another way to go:
;;  CAB 10/07/08
;; (splitdirs "c:\\123\\456\\789") returns ("c:" "123" "456" "789")
(defun splitdirs (str / lst pos)
 (while (or (setq pos (vl-string-search "\\" str))
            (setq pos (vl-string-search "/" str)))
   (setq lst (cons (substr str 1 pos) lst)
         str (substr str (+ pos 2))))
 (if (> (strlen str) 0) (setq lst (cons str lst)))
 (reverse lst)
Is there any way to go back to there folder before dwgs no matter how many folders are after it. Where would I put what you guess did above in my lisp already given?
Thanks again
Thanks again
Any Help!!
(defun c:test(/ dir lst NewDir idx)
 (setq dir "M:\\1234\\Target Dir\\dwgs\\electrical")
 (setq lst (splitdirs dir))
 (setq NewDir (car lst))
 (setq idx 0)
 (while (/= "DWGS" (strcase (nth (setq idx (1+ idx)) lst)))
   (setq NewDir (strcat NewDir "\\" (nth idx lst)))
 (print NewDir)
;;  CAB 10/07/08
 (reverse lst)
 (setq idx 0)
 (print NewDir)
;;  CAB 10/07/08
 (reverse lst)
When I do your is does not do anything? How come?
The test lisp starts with this:
and returns this:
Command: test
"M:\\1234\\Target Dir"
This is a tool, a subroutine.
Do you need help integrating it into your lisp?
and returns this:
Command: test
Yes please I'm lost!!!!
Here, you debug it.:wink: :wink:
(defun c:BindIt (/)
;;  CAB 10/07/08
 (reverse lst)
 ;;  remove the last 2 dirs
 (setq lst (reverse (cddr (reverse (splitdirs vPrefix)))))
 (setq vPrefix "")
 (mapcar '(lambda(x) (setq vPrefix (strcat vPrefix x "\\"))) lst)
 (initget "Bound Email")
 (setq vDir (getkword "\nSave file to [Email/Bound] <Bound>: "))
 (cond
   ((or (null vDir)(= "Bound" vAns))
   (t
 (cond
   ((and (null (vl-file-directory-p vDir))
         (null (vl-mkdir vDir))
    (prompt "\nError - Could not create Folder.")
   (t ; folder exist
     (command ".saveas" "" (strcat vDir "\\" vDateStr "-" vName))
(defun c:BindIt (/)
;;  CAB 10/07/08
 (reverse lst)
 (setq vPrefix "")
 (cond
   (t
 (cond
   (t ; folder exist
I got it to work, but instead of it taking the file and putting it in the bound/E-mail folder, then a folder created with the date like 2008-10-22. If puts it in the bound/e-mail folder and just puts the date at the beginning of the file name. How come it does this.
I got it to work
Did you change anything to get it to work?
I changed the code to do that thinking you would not want to create folders for every date
but to just create unique file names instead.
Silly me.:)
If you want I can revise it.
no you had everything working.
Revised code:
(defun c:BindIt (/)
;;  CAB 10/07/08
 (reverse lst)
 (setq vPrefix "")
 (cond
   (t
 ;;  The following is to create a seperate directory for each date
 (setq vDir (strcat vDir "\\" vDateStr))
 (cond
   (t ; folder exist
     ;;(command ".saveas" "" (strcat vDir "\\" vDateStr "-" vName))
     (command ".saveas" "" (strcat vDir "\\" vName))
Revised code:
(defun c:BindIt (/)
;;  CAB 10/07/08
 (reverse lst)
 (setq vPrefix "")
 (cond
   (t
 (cond
   (t ; folder exist
Ok this works good. If I have a drawing on my C drive, but if I have something on my m drive it keeps on saying could not create folder how come. I even tried changing the c:\\ to m:\\ but still the samething how come?
The problem is if the Bind or Email folders are not already created.
This should fix it.
(defun c:BindIt (/ LST VANS VDATE VDATESTR VDAY VDIA VDIR VECHO VMONTH VNAME VPREFIX VYEAR X)
 ;;  CAB 10/07/08
   (reverse lst)
 (setq vPrefix "")
 (mapcar '(lambda (x) (setq vPrefix (strcat vPrefix x "\\"))) lst)
 (cond
   ((or (null vDir) (= "Bound" vAns))
    (vl-mkdir vDir)
   (t
    (vl-mkdir vDir)
 (if (vl-file-directory-p vDir)
     (cond
        (prompt (strcat "\nError - Could not create Folder: " vDir))
       (t ; folder exist
This should fix it.
 ;;  CAB 10/07/08
   (reverse lst)
 (setq vPrefix "")
 (cond
    (vl-mkdir vDir)
   (t
    (vl-mkdir vDir)
     (cond
       (t ; folder exist
thanks works perfect. I just added one thing at the end so it will bind and purge, then resave it
At the end I added this.
(command "_.xref" "bind" "*")
(command "_.purge" "" "all" "n" "" "_.purge" "all" "" "n" "" "_.purge" "all" "" "n")
(command ".save")
Thanks for all your help I hope this helps someone else.
Put your code in this section so it will only be executed if no errors.
        (t ; folder exist
        ;;  Add your code here
        (t ; folder exist
Is there a way to put the purge and bind at the beginning, then instead of savas is it possible to do a aectoacad. Not changing anything but the bind and purge will be done before aectoacad to the folder location.
Oops, use this:
        (t ; folder exist
