Hi I have a bunch of drawings where some contain an xref that was xclipped and others did not. I want to run a command on the files that use the xclip to generate the xclip frame polyline
So to the effect of:
(if (**xclip is used**)
(command "xclip" "all" "" "p")
Is there a way to write a conditional statement to prove xclip is used/active in the dwg? Does using xclip leave any sort of marker on the dwg file?
Thank you!
Using some code I already had written:
(defun HasXClip ( / a b c d e f )
   (and
       (while (setq a (tblnext "BLOCK" (null a)))
           (if (= 4 (logand 4 (cdr (assoc 70 a))))
               (setq b (cons "," (cons (cdr (assoc 2 a)) b)))
               b
       (setq c (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (cdr b))))))
       (setq d -1)
           (while (and (not f) (setq e (ssname c (setq d (1+ d)))))
               (setq f (LM:XClipBoundary e))
           f
(defun LM:XClipBoundary ( ename / xdict )
   (if
       (setq xdict (cdr (assoc 360 (entget ename))))
       (LM:XClipBoundary xdict)
       (if
           (and
               (eq "SPATIAL_FILTER" (cdr (assoc 0 (setq ename (entget ename)))))
               (eq 1 (cdr (assoc 71 ename)))
           (   (lambda ( massoc ) (massoc 10 ename))
               (lambda ( key elist / item )
                   (if (setq item (assoc key elist))
                       (cons (cdr item) (massoc key (cdr (member item elist))))
Call with:
(HasXClip)
Will return T if drawing contains an XRef with an XClip.
Hence in your IF statement:
(if (HasXClip)
Wow thank you so much Lee! You're the best!
