Copy along a P-Line path
Is there a way to copy an object along a p-line path.???
Make the object a block, then use the Measure (or Divide) command with the block option.
Thanks. I did that. However I want to have my block spaced out exactly 1' apart.??? How do I do that.???
  • 1 month later...
how i could copy object along p line with uneven distance?
search on-line for PUT.LSP
Someone, I think lpseifert, posted one here some time ago called measureplinepts.lsp, but it might take some searching.
Here's one similar to the one Rusty referred to. You could modify it to insert blocks instead of points.
;places point at specified station along a polyline, measured from start LPS 2008
(defun c:pop ()
(vl-load-com)
(setq oldosnap (getvar "osmode"))
(setvar "osmode" 0)
(command "ucs" "w")
(if (/= (getvar "pdmode") 3)(setvar "pdmode" 3))
(setq ob (entsel "Select curve: "))
(setq p2 (getreal "\n Specify Distance : "))
(setq obj (vlax-ename->vla-object (car ob)))
(setq pt1 (vlax-curve-getPointAtDist Obj p2))
(command "Point" pt1)
(command "ucs" "p")
(setvar "osmode" oldosnap)
>>edit
never mind, here is the PUT.lsp, seems to be what you want
Here is some code for inserting blocks along a pline based on number required per segment rather than distance. Also rotates block you may want to remove that part. Block name is holden
A good oppurtunity to say thanks for others helping me with this code.
Sub draw_vehicle()
Dim CAR As String
Dim arcobj As AcadArc
Dim oPoly As AcadEntity
Dim blkobj As AcadEntity
Dim retVal As Variant
Dim snapPt As Variant
Dim oCoords As Variant
Dim blpnt1() As Variant
ReDim blpnt1(100)
Dim blpnt2() As Variant
ReDim blpnt2(100)
Dim vertPt(0 To 2) As Double
Dim Pt1(0 To 2) As Double
Dim Pt2(0 To 2) As Double
Dim newPt(0 To 2) As Double
Dim iCnt, w, x, y, z As Integer
Dim cRad, interval, blkangle As Double
Dim circObj As AcadCircle
Dim lineObj As AcadLine
On Error GoTo Something_Wrong
For Each Item In ThisDrawing.Blocks
If Item.Name = "holden" Then GoTo continue_on
Next Item
' exits out of program
GoTo Exit_out
continue_on:
w = 1
ThisDrawing.Utility.GetEntity oPoly, snapPt, vbCr & "Select polyline :"
If oPoly.ObjectName = "AcDbPolyline" Then
oCoords = oPoly.Coordinates
Else: MsgBox "This object is not a polyline!"
Exit Sub
End If
interval = CDbl(InputBox("Enter interval:", , 1#))
If interval < 1 Then
interval = 1
End If
For iCnt = 0 To UBound(oCoords) - 2 Step 2
Pt1(0) = oCoords(iCnt): Pt1(1) = oCoords(iCnt + 1): Pt1(2) = 0#
newPt(0) = Pt1(0)
newPt(1) = Pt1(1)
newPt(2) = 0#
iCnt = iCnt + 2
Pt2(0) = oCoords(iCnt): Pt2(1) = oCoords(iCnt + 1): Pt2(2) = 0#
x = (Pt1(0) - Pt2(0)) / interval
y = (Pt1(1) - Pt2(1)) / interval
'reset back 2 values
iCnt = iCnt - 2
cRad = 2.8
startang = 4.712
endang = 1.57
CAR = "HOLDEN"
For z = 1 To interval
vertPt(0) = newPt(0) - x
vertPt(1) = newPt(1) - y
vertPt(2) = 0#
'blpnt1(w) = vertPt
Set arcobj = ThisDrawing.ModelSpace.AddArc(vertPt, cRad, endang, startang)
retval2 = arcobj.IntersectWith(oPoly, acExtendOtherEntity)
arcobj.Delete
Set arcobj = Nothing
blkangle = ThisDrawing.Utility.AngleFromXAxis(retval2, vertPt)
Set blkobj = ThisDrawing.ModelSpace.InsertBlock(vertPt, CAR, 1#, 1#, 1#, blkangle)
Set blkobj = Nothing
w = w + 1
newPt(0) = newPt(0) - x
newPt(1) = newPt(1) - y
Next z
Next iCnt
Something_Wrong:
MsgBox Err.Description
Exit_out:
End Sub
