DanCorbett1 Posted September 28, 2011 Posted September 28, 2011 Hi, I'm having problems with lineweights. It shows up too dark whenever I plot to both pdf and the printer (Kyocera KM-2560 KX). Ive tried adjusting the ctb file (changing thicknesses of colours) but to no avail. This problem does not occur for my colleagues, with exactly the same ctb file. So is it a general autocad setting problem? Any help would be greatly appreciated, Daniel Quote
Dipali Posted September 28, 2011 Posted September 28, 2011 we had this problem on random since long time and i recently figured out the reason. it could be the same for u. check the unit of paper size u select while printing because our drawing was in inches and if we select A3 size it useto print very dark because A3 for standard printer settings in mm so if i selct 11x17 as paper size, it started printing fine........... Quote
DanCorbett1 Posted September 28, 2011 Author Posted September 28, 2011 thanks, ill give that a go Quote
