ryank7 Posted September 27, 2011 Share Posted September 27, 2011 I'm having trouble displaying the units for dimensions. The issue is with the suffix. When I add the " suffix to indicate inches autocad also adds the suffix to the angular dimension. 2 questions... Is there a way to suppress the suffix for angular dimensions? Do I need to have a dimension style just for angular dimension? I do not want to dimension in architectural because I don't want the dimensions to change to feet and inches. Quote Link to comment Share on other sites More sharing options...
nestly Posted September 27, 2011 Share Posted September 27, 2011 You can set up a "child" dimension style, so one dimstyle automatically adds the suffix to linear and aligned dimensions, but not to angular, radial or diametric dimensions. Here's a couple of demo videos I did for previous threads here at Cadtutor Quote Link to comment Share on other sites More sharing options...
ryank7 Posted September 27, 2011 Author Share Posted September 27, 2011 That is perfect! Exactly what I was looking for. Thank you nestly. Quote Link to comment Share on other sites More sharing options...
Dipali Posted September 27, 2011 Share Posted September 27, 2011 good you found what u were looking for while i was doing a bit of search on your query and found this thread http://www.cadtutor.net/forum/showthread.php?61901-Add-Prefix-Suffix-to-Multiple-Dimensions&highlight=remove+suffix%2Bangular+dimensions it might be useful to u........ Quote Link to comment Share on other sites More sharing options...
ryank7 Posted September 27, 2011 Author Share Posted September 27, 2011 Thanks for looking Dipali. That is a little more in depth than I need. Quote Link to comment Share on other sites More sharing options...
