I'm having trouble displaying the units for dimensions. The issue is with the suffix.
When I add the " suffix to indicate inches autocad also adds the suffix to the angular dimension.
2 questions...
Is there a way to suppress the suffix for angular dimensions?
Do I need to have a dimension style just for angular dimension?
I do not want to dimension in architectural because I don't want the dimensions to change to feet and inches.
You can set up a "child" dimension style, so one dimstyle automatically adds the suffix to linear and aligned dimensions, but not to angular, radial or diametric dimensions. Here's a couple of demo videos I did for previous threads here at Cadtutor
That is perfect! Exactly what I was looking for.
Thank you nestly.
Thanks for looking Dipali. That is a little more in depth than I need.
