3dwannab Posted March 3, 2017 Posted March 3, 2017 Sorry to annoy you guys again but I managed to get it to work (sort of). But it's not selecting the correct boundary in some cases. See attached drawing. If you select the hatch for plaster in that, it'll select the adjacent boundary too. Any help here would be greatly appreciated. (defun c:Test (/ _2dpt ss1 ss2 ss3 a b i1 i2 ) (vl-load-com) (setq ss3 (ssadd)) (defun _2dpt (pt) (list (car pt) (cadr pt) 0.)) (if (setq ss1 (ssget '((0 . "HATCH")))) (repeat (setq i1 (sslength ss1)) (vla-getboundingbox (vlax-ename->vla-object (ssname ss1 (setq i1 (1- i1)))) 'a 'b) (if (setq ss2 (apply 'ssget (append (list "_W") (mapcar '(lambda (x) (trans (_2dpt (vlax-safearray->list x)) 0 1)) (list a b)) '(((0 . "~HATCH,ARC,CIRCLE,LINE,LWPOLYLINE"))) ) ) ) (repeat (setq i2 (sslength ss2)) (ssadd (ssname ss2 (setq i2 (1- i2))) ss3) ) ) ) ) (sssetfirst nil ss3) (princ (strcat "\nNumber of found hatch boundaries : < " (itoa (sslength ss3)) " >")) (command "._regen")(princ) ) Selection problem.dwg Quote
3dwannab Posted November 8 Posted November 8 This works for hatches that are associated with the objects. Lee Mac working his magic once again. 1 Quote
