Try to check the image, porblem regarding the UCS.
I will modify some of the file that was given to me, when I open the file, the axis is like this (the one drawn below, with the yellow X and Y axis), so i tried to change it using the UCS command, so I already changed the axis (same as the drawing below, the original axis.) BUT!, when the axis is already changed, the cursor turns like that (also see the image below), so How can I change my cursor? Who knows about this one, need your help, thanks
Thanks for the SNAPANG command, i forgot that command already.
