puffeltje Posted October 14, 2008 Posted October 14, 2008 Is it possible within VBA to create a list of all the lines (with their starting- and ending-coordinates) in a drawing? VBA (or VB) is not new to me, but the combination with Autocad is. Quote
rkmcswain Posted October 14, 2008 Posted October 14, 2008 Is it possible within VBA to create a list of all the lines (with their starting- and ending-coordinates) in a drawing? Yes. Create a filtered selection set for LINE entities, then iterate this selection set, querying the desired properties. The help file contains an example of filtering a selection set, and there is a good tutorial here: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=2768231&linkID=9240615 Quote
fixo Posted October 14, 2008 Posted October 14, 2008 Is it possible within VBA to create a list of all the lines (with their starting- and ending-coordinates) in a drawing? VBA (or VB) is not new to me, but the combination with Autocad is. Welcome on board! Try this example Option Explicit Sub AllLinesData() Dim oSset As AcadSelectionSet Dim oEnt As AcadEntity Dim fcode(0) As Integer Dim fData(0) As Variant Dim dxfcode, dxfdata Dim setName As String Dim i As Integer Dim n As Integer Dim s As String fcode(0) = 0 fData(0) = "LINE" dxfcode = fcode dxfdata = fData setName = "$Lines$" '// make sure the selection set does not exist For i = 0 To ThisDrawing.SelectionSets.Count - 1 If ThisDrawing.SelectionSets.Item(i).Name = setName Then '// if this named selection set is already exist then delete it ThisDrawing.SelectionSets.Item(i).Delete Exit For End If Next i '// add new selection set with this name Set oSset = ThisDrawing.SelectionSets.Add(setName) oSset.Select acSelectionSetAll, , , dxfcode, dxfdata On Error GoTo Err_Control '// loop through all lines ReDim lineArr(0 To oSset.Count - 1, 0 To 6) As Variant For n = 0 To oSset.Count - 1 Dim cEnt As AcadEntity Set cEnt = oSset.Item(n) Dim oLine As AcadLine Set oLine = cEnt Dim startp As Variant '// get the start point startp = oLine.StartPoint Dim endp As Variant '// get the end point endp = oLine.EndPoint '// collect line handles and points into a two-dimensional array lineArr(n, 0) = oLine.Handle lineArr(n, 1) = startp(0) lineArr(n, 2) = startp(1) lineArr(n, 3) = startp(2) lineArr(n, 4) = endp(0) lineArr(n, 5) = endp(1) lineArr(n, 6) = endp(2) Next n '// clean up memory oSset.Delete '// do what you want with array 'lineArr' here, e.g. write data to the text file etc. Open "C:\AllLines.txt" For Output As #1 'Open file for output For n = 0 To UBound(lineArr, 1) s = "" For i = 0 To UBound(lineArr, 2) s = s & CStr(lineArr(n, i)) & "," Next i Write #1, Left(s, Len(s) - 1) 'Write comma-delimited data (cut the last comma from string) Next n Close #1 'Close file Err_Control: MsgBox Err.Description End Sub ~'J'~ Quote
puffeltje Posted October 15, 2008 Author Posted October 15, 2008 Thanks, tried the code and it does what i need. With this code i can complete my program a little bit more. Quote
puffeltje Posted October 16, 2008 Author Posted October 16, 2008 I addapted the code to get the start- and enppoints for LWPolylines. This works for lwpolylines with 1 vertex. When i draw a lwpolyline with multiple vertices i see that the groupcode "90" represents the number of vertices. How can i read the context of groupcode "90", or is there an otherway to determine the number of vertices? Quote
fixo Posted October 16, 2008 Posted October 16, 2008 Try insread this slightly edited version Option Explicit Sub AllPlinesData() Dim oSset As AcadSelectionSet Dim oEnt As AcadEntity Dim fcode(0) As Integer Dim fData(0) As Variant Dim dxfcode, dxfdata Dim setName As String Dim i As Integer Dim n As Integer Dim s As String fcode(0) = 0 fData(0) = "LWPOLYLINE" dxfcode = fcode dxfdata = fData setName = "$Plines$" '// make sure the selection set does not exist For i = 0 To ThisDrawing.SelectionSets.Count - 1 If ThisDrawing.SelectionSets.Item(i).Name = setName Then '// if this named selection set is already exist then delete it ThisDrawing.SelectionSets.Item(i).Delete Exit For End If Next i '// add new selection set with this name Set oSset = ThisDrawing.SelectionSets.Add(setName) oSset.Select acSelectionSetAll, , , dxfcode, dxfdata On Error GoTo Err_Control '// loop through the all light polylines ReDim plineAr(0 To oSset.Count - 1, 0 To 4) As Variant For n = 0 To oSset.Count - 1 Dim cEnt As AcadEntity Set cEnt = oSset.Item(n) Dim oPline As AcadLWPolyline Set oPline = cEnt Dim coord As Variant '// get coordinates coord = oPline.Coordinates '// collect polyline handles and points into a two-dimensional array plineAr(n, 0) = oPline.Handle plineAr(n, 1) = coord(0) ' <--X start point plineAr(n, 2) = coord(1) ' <--Y start point plineAr(n, 3) = coord(UBound(coord) - 1) ' <--X end point plineAr(n, 4) = coord(UBound(coord)) ' <--Y end point Next n '// clean up memory oSset.Delete '// do what you want with array 'plineAr' here, e.g. write data to the text file etc. Open "C:\AllPlines.txt" For Output As #1 'Open file for output For n = 0 To UBound(plineAr, 1) s = "" For i = 0 To UBound(plineAr, 2) s = s & CStr(plineAr(n, i)) & "," Next i Write #1, Left(s, Len(s) - 1) 'Write comma-delimited data (cut the last comma from string) Next n Close #1 'Close file Err_Control: MsgBox Err.Description End Sub ~'J'~ Quote
puffeltje Posted October 17, 2008 Author Posted October 17, 2008 The code only returns the beginning and endig of the polyline. i changed a part of the code to this: '// get coordinates coord = oPline.Coordinates '// collect polyline handles and points into a two-dimensional array xtemp = coord(0) ' <--X start point ytemp = coord(1) ' <--Y start point For j = 0 To (UBound(coord) - 1) / 2 - 1 [indent]ReDim Preserve plinear(3, PLindex) As Variant ' <--create vertex in array plinear(0, PLindex) = xtemp ' <--X start point plinear(1, PLindex) = ytemp ' <--Y start point plinear(2, PLindex) = coord(j * 2 + 2) ' <--X end point plinear(3, PLindex) = coord(j * 2 + 3) ' <--Y end point xtemp = plinear(2, PLindex) ' <--save X end point as new X start point ytemp = plinear(3, PLindex) ' <--save Y end point as new Y start point PLindex = PLindex + 1 ' <--increment number of vertex [/indent] Next j Now all the start points and end points of the vertices are returned. Thanks all for the help Quote
FELIX Posted February 23, 2009 Posted February 23, 2009 puffeltje, I tried incorporating your code to sample code that Fixo provided and was unable to get it to execute. Can you help. Would like to try your code. Thanks. Quote
puffeltje Posted February 24, 2009 Author Posted February 24, 2009 Oeps, i didn't post all my changes:oops: . Here is the working code: Option Explicit Sub AllPlinesData() Dim oSset As AcadSelectionSet Dim oEnt As AcadEntity Dim fcode(0) As Integer Dim fData(0) As Variant Dim dxfcode, dxfdata Dim setName As String Dim i As Integer Dim n As Integer Dim s As String Dim xtemp Dim ytemp Dim j Dim PLindex fcode(0) = 0 fData(0) = "LWPOLYLINE" dxfcode = fcode dxfdata = fData setName = "$Plines$" '// make sure the selection set does not exist For i = 0 To ThisDrawing.SelectionSets.Count - 1 If ThisDrawing.SelectionSets.Item(i).Name = setName Then '// if this named selection set is already exist then delete it ThisDrawing.SelectionSets.Item(i).Delete Exit For End If Next i '// add new selection set with this name Set oSset = ThisDrawing.SelectionSets.Add(setName) oSset.Select acSelectionSetAll, , , dxfcode, dxfdata On Error GoTo Err_Control '// loop through the all light polylines ReDim plinear(0 To 3, 0 To oSset.Count - 1) As Variant PLindex = 0 For n = 0 To oSset.Count - 1 Dim cEnt As AcadEntity Set cEnt = oSset.Item(n) Dim oPline As AcadLWPolyline Set oPline = cEnt Dim coord As Variant '// get coordinates coord = oPline.Coordinates '// collect polyline handles and points into a two-dimensional array xtemp = coord(0) ' <--X start point ytemp = coord(1) ' <--Y start point For j = 0 To (UBound(coord) - 1) / 2 - 1 ReDim Preserve plinear(3, PLindex) As Variant ' <--create vertex in array plinear(0, PLindex) = xtemp ' <--X start point plinear(1, PLindex) = ytemp ' <--Y start point plinear(2, PLindex) = coord(j * 2 + 2) ' <--X end point plinear(3, PLindex) = coord(j * 2 + 3) ' <--Y end point xtemp = plinear(2, PLindex) ' <--save X end point as new X start point ytemp = plinear(3, PLindex) ' <--save Y end point as new Y start point PLindex = PLindex + 1 ' <--increment number of vertex Next j Next n '// clean up memory oSset.Delete '// do what you want with array 'plineAr' here, e.g. write data to the text file etc. Open "C:\AllPlines.txt" For Output As #1 'Open file for output For n = 0 To UBound(plinear, 2) Write #1, plinear(0, n); plinear(1, n); plinear(2, n); plinear(3, n) Next n Close #1 'Close file Err_Control: MsgBox Err.Description End Sub In the file you get all the segments of the polylines. I only tried it with segments with the same startingwidth and endingwidth (and no curves). I think it can work for all sort of polylines, but i am not shure. Quote
FELIX Posted February 24, 2009 Posted February 24, 2009 Thanks for the update, puffeltje. I ran the code and looks like it worked. I will add the object entity handle number in the code again since your code doesn't have that. Beside that I did not get any errors. Thanks again. Quote
FELIX Posted February 24, 2009 Posted February 24, 2009 puffeltje, Do you think you can help me by adding the object entity handle number or ID, the segment number, and the segment length to your code? Something like this: 1A, Segment 1, x coord, y coord, x2 coord, y2coord, length 1A, segment 2, x coord, y coord, x2 coord, y2coord, length Quote
