I'm plotting a Township Dimension sheet that has links to corner tie sheets on each section corner. Ideally I'd like to plot this using the "DWG to PDF" plotter and have it saved as a PDF so when it's put on our website you can easily pull up each relevant tie sheet from the links.
If I plot this as a .DWF file the hyperlinks work great. However, I highly doubt too many people can easily open DWF files so I'd like to keep it in a PDF format. Is there any way to plot to PDF using AutoCAD and keep the hyperlinks? I'm starting to think the only way to have hyperlinks in a PDF document is to create them manually using Adobe Acrobat (which would be A LOT of work). Any help would be appreciated, thanks!
