Select entities by color property.
teknomatika
I need one more help:
I need an autolisp routine that allows from a pick in just one entity, select all entities in drwaing that have the same color property.
The entities can be multiple and belong to different layers.
It is true that in autocad the "qselect" tool already exists, but this does not always work, in addition to not being very direct.
Tanks.
This ?.....
(sssetfirst nil (ssget "_X" (list (cons 62 1)))) ;;; Number one indicates to color Red
This?
(defun c:SelectByColour ( / c d e l )
   (if (setq e (car (entsel)))
           (setq c
               (cond
                   (   (cdr (assoc 62 (entget e)))   )
                   (   (abs (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 (entget e)))))))   )
           (while (setq d (tblnext "LAYER" (null d)))
               (if (= c (abs (cdr (assoc 62 d))))
                   (setq l (cons "," (cons (cdr (assoc 2 d)) l)))
           (sssetfirst nil
               (ssget "_X"
                   (if l
                       (list
                           (cons -4 "<OR")
                               (cons 62 c)
                               (cons -4 "<AND")
                                   (cons 62 256)
                                   (cons 8 (apply 'strcat (cdr l)))
                               (cons -4 "AND>")
                           (cons -4 "OR>")
                       (list (cons 62 c))
Lee Mac,
Excellent. That's right. Much more direct than the QSELECT.
However, I found that in the case of blocks, the selection includes the native color of the layer, even when the color of block it is different.
But this is a detail.
Tanks.
You will only be able to select Primary entities with ssget.
  • Agree 1
I understand.
Anyway, the routine is excellent.
Thank you.
This may be of interest to you (the FilteredSelection.LSP file): http://www.theswamp.org/index.php?topic=35028.msg402471#msg402471
eg.
Command: ft
Filter choice: [block/Color/Entity/Layer/linetYpe] <Layer>: c
Ignore locked layers? [Yes/No] <No>:
Select object for color:
Color: "(5 . Blue)" selected.
Select objects: Specify opposite corner: 1 found
Select objects: al
1 found (1 duplicate), 1 total
Select objects:
You can also use SSX or Filter
  • 8 years later...
Hello,
is it possible to select by given index color (1:red, 2:yellow, 3:green etc) instead of select source object?
Maybe use repeat for each color number, see Tharwat post.
Enter a string say 1,2,3 use parse csv to make a list then a foreach to process the list. Similar to 1st suggestion how do you want to do the 1 2 3 ?
   (if (setq e (getint "\nColour index :"))
           (setq c
               (cond
                   (   e   )
                   (   (abs (cdr (assoc 62 (tblsearch "LAYER" 0))))   )
           (sssetfirst nil
               (ssget
                   (if l
                       (list
                           (cons -4 "<OR")
                               (cons 62 c)
                               (cons -4 "<AND")
                                   (cons 62 256)
                               (cons -4 "AND>")
                           (cons -4 "OR>")
                       (list (cons 62 c))
I have adopt above LeeMac code acc. to my need. thnx. I dont know if it is logical but it works :)
Untested.
(defun c:SelectByColour (/ c d l)
  (if (setq c (getint "\nColour index :"))
      (sssetfirst
        nil
        (ssget
          (if l
            (list
              (cons -4 "<OR")
              (cons 62 c)
              (cons -4 "<AND")
              (cons 62 256)
              (cons -4 "AND>")
              (cons -4 "OR>")
            (list (cons 62 c))
  • 1 year later...
This is shorter (sorry Lee Mac: any comment is appreciated)
(defun c:SelectByColor(/ TargEnt TargColor)
 (setq TargEnt (car (entsel "\nSelect object with Color to select: ")))
 (setq TargColor (assoc 62 (entget TargEnt)))
 (sssetfirst nil (ssget "_X" (list TargColor)))
 (print TargColor)
Note: doesnt work for "ByLayer" Color.  Lee Mack's is perfet as alwayse :)
Edited by hseeda
 (print TargColor)
Be sure to also test for a valid selection prior to calling (entget TargEnt) otherwise your code will error.
