Bill2X Posted September 17, 2011 Share Posted September 17, 2011 There I was, fooling around in the CUI window adding panels to my Home ribbon, then when I was through, I noticed all my points disappeared. Trying to figure out what went wrong, I learned; 1. my points are not missing, just not visible in the model tab. They exist, they show up in toolspace>points, and in layout views. 2. they are as if they are on a frozen layer. I can't see them and I can't select them with a cursor window, but I can select them with qselect, which I know they are selected because it tells me so on the command line. 3. not all points are gone from sight in the model tab, just the ones which were on and thawed while I was tinkering with CUI. If it was vice-versa, i.e. I could see them in the model but not in a viewport I could blame it on viewport freeze, but not so. I messed with PDMODE and PDSIZE, of course to no avail. I am working in Civil 3D 2010 and more than a little baffled. Thanks, Bill Quote Link to comment Share on other sites More sharing options...
Chip904 Posted September 26, 2022 Share Posted September 26, 2022 Did you find a solution? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted September 27, 2022 Share Posted September 27, 2022 Sorry to tell you this, but you're probably not going to get a response on a ten-year-old issue. Poor Bill2X never came back. Welcome to the forum! Quote Link to comment Share on other sites More sharing options...
