frenkas Posted September 15, 2011 Posted September 15, 2011 Hello, Simple question. Is it possible to get dynamic properties from AcadBlock not AcadBlockRefference? As I didn't find any solution, I implemented this function: Private Function ExistsDynPr(bb As AcadBlock, PropName As String) As Boolean Dim oProps As Variant Dim oDblkProp As AcadDynamicBlockReferenceProperty ', ap As AcadDynamicBlockReferenceProperty Dim I As Integer, pp(0 To 2) As Double, abr As AcadBlockReference Set abr = ThisDrawing.ModelSpace.InsertBlock(pp, bb.Name, 1, 1, 1, 0) 'bandom iterpti [laikinai] ExistsDynPr = False If abr.IsDynamicBlock Then oProps = abr.GetDynamicBlockProperties For I = 0 To UBound(oProps) Set oDblkProp = oProps(I) If oDblkProp.PropertyName = PropName Then ExistsDynPr = True abr.Delete Exit Function End If Next End If abr.Delete End Function Is there any side effects or risks of inserting block? If no I'll stick to this function, though I think it's not very nice solution. Quote
meyerforhire Posted January 4, 2012 Posted January 4, 2012 Could you do something like: Dim objEnt as AcadEntity For Each objEnt in AcadBlock If TypeOf objEnt is AcadDynamicBlockReferenceProperty Then ExistsDynPr = true Next I think that should work without having to insert. Quote
meyerforhire Posted January 12, 2012 Posted January 12, 2012 I think I steered you wrong. I attempted to cycle through the dyn props of an AcadBlock and couldn't get an acknowledgement that any AcadDynamicBlockReferenceProperties were included in the AcadEntityObject inside the AcadBlock. I tried to cycle through a bunch of blocks and delete all of the dynamic properties--I'm fed up with em'. Users love them, but there really hard to keep track of using vba. Check out the post I made a week or so ago titled "Dynamic Block Properties Quandry." It doesn't look like ACAD can keep track of the cohesive in a manner either--at least that I've found. No one has answered me back on that question I posted. Quote
