I have a block that has MText in it. I need it to refrence the sheet set manager "CurrentSheetTitle"
sometimes the title can be long, so i am using mtext so it will wrap correctly. when i insert the block other attribut fields display properly, but the mtext for this field does not. after i explode the block, then the MText field displays properly.
i have another MText field that reads plot time and user name. that is contained in the same block and updated perfectly.
any ideas on this or any way to make it better.
