swimwsr Posted September 12, 2011 Posted September 12, 2011 I have autocad 2012 and i am trying to add data to existing points. I have over 300 cogo points that need custom properties added, such as top elevation/bottom elevation/classification code. I trid to add the properties using the user-defined property classifaction tool, but then would I have to insert all the data by hand? I know there is a way i can attach the data from an excel sheet to cogo points, but AutoCAD 2012 help service stinks and i cant figure it out. Any ideas? thanks Quote
BlackBox Posted September 12, 2011 Posted September 12, 2011 Welcome to CADTutor, and the world of Object Data (OD). However, you may need to instead consider XData, as I *believe* OD requires Map. HTH Quote
swimwsr Posted September 12, 2011 Author Posted September 12, 2011 I have 2012 civil 3d/ map. I have used object data before, but never from an outside source. (I have only needed to use default value) i do not know how to link the excel or access file to the object data so that i do not have to enter it in for all 300 points. I have tried useing the data link tool, but never could attach everything correctly. I have never used XData, i will look into that. Quote
Murph_map Posted September 13, 2011 Posted September 13, 2011 I have 2012 civil 3d/ map. I have used object data before, but never from an outside source. (I have only needed to use default value) i do not know how to link the excel or access file to the object data so that i do not have to enter it in for all 300 points. I have tried useing the data link tool, but never could attach everything correctly. I have never used XData, i will look into that. What data is in the excel file? If it has the X,Y &Z coordinates along with the inverts just import the points as Civil3D points. Look in the tutorials for points inports in Civil3D. Also post in the Civil3D forum for more help on it. Quote
BlackBox Posted September 13, 2011 Posted September 13, 2011 Now that we know you're using C3D, use Murph's advice. :wink: Quote
SLW210 Posted September 13, 2011 Posted September 13, 2011 It is always nice to know what program you are using. You need to properly fill out your info for better responses. I am moving this thread to Civil3D forum. Quote
swimwsr Posted September 13, 2011 Author Posted September 13, 2011 yea sorry about not being specific. I have tried to import the points, however, I cannot figure out how to add extra information to the points. I need to attach labels that will show not only the northing, easting, elevation, and label description, but also other misc info such as depth, classification code, etc. I have even tried to insert this data as user-defined properties then export it to a file to figure out the format, but it did not show up. How do i insert this information and what type of file should i import it as? Quote
