CyberAngel Posted September 12, 2011 Posted September 12, 2011 See the attached file. It came from a surveyor. The surveyor is not answering his phone today. There are three blocks that show the elevation of the edge of pavement. When I edit the block, there is only a point, no attributes. When I double-click on the block, I can edit the attributes. Can anyone tell me: a) what type of object(s) I'm dealing with here; and more importantly b) how to change properties of the attributes all at once instead of one at a time? ACAD-survey.dwgFetching info... Quote
dbroada Posted September 12, 2011 Posted September 12, 2011 looks fine here. do you already have an block named "DOT" in your drawing already? Quote
SLW210 Posted September 12, 2011 Posted September 12, 2011 I have the same problem as CyberAngel. BATTMAN doesn't work Command Line said: Command: battmanThis drawing contains no attributed blocks. Command: *Cancel* and BEDIT only has the point. Quote
dbroada Posted September 12, 2011 Posted September 12, 2011 I guess you will have to upgrade to 2008 then. Quote
dbroada Posted September 12, 2011 Posted September 12, 2011 OK, I've BEDITed it and see what you mean. Basically the OP had the block with 3 attributes and then erased them (by BEDIT probably) and then sent the block to you. /You therefore have the block as it was on show but only have access to the updated block reference. The only way round this is to get the original block or reconstruct it yourself (and then ATTSYNC it). Quote
SLW210 Posted September 12, 2011 Posted September 12, 2011 dbroada said: OK, I've BEDITed it and see what you mean. Basically the OP had the block with 3 attributes and then erased them (by BEDIT probably) and then sent the block to you. /You therefore have the block as it was on show but only have access to the updated block reference. The only way round this is to get the original block or reconstruct it yourself (and then ATTSYNC it). That would be my guess and I have duplicated that scenario. Quote
CyberAngel Posted September 12, 2011 Author Posted September 12, 2011 Okay, thanks. I suppose it could be worse, they could all be anonymous blocks. Quote
