I have a problem with absolute and relative coordinate regarding drawing an arc.
From my previous studies, I thought whenever I input coordinates in command line, in order to use absolute coordinates I just enter them. If I want to use relative coord, then I can prefix them with @ sign.
For an arc I input as follows: start point: 0,0 2nd point: 500,500 end point: 1000,0. I was expecting to get a half circle from origin to 1000,0 point but to my surprise I find out that CAD gets the input coordinates as relative.
Is this behavior same for all other object drawings?
1.dwgFetching info...
Dynamic Input turned ON = Black
Dynamic Input turned OFF = Red
Why? .... because the default (OOTB) setting for Dynamic input is "Relative Coordinates" so it automatically adds the @ symbol.
If you want to change the default settings, do it through DSETTINGS or use the # symbol to specify Absolute coordinates.
Dear Nestly
Thanks a lot. Like as always your reply is perfect. I have to admit that I was unaware of this point.
AutoCad is such a great and detailed program that has commands for every single point.
This Forum is really a good place to learn and enhance knowledge about AutoCAD.
Just one minor point. You mentioned:
I didn't get the point where are you referring to? In your posted image I couldn't find your quotes. But my problem is resolved.
Edited by khoshravan
add note
"Red" and "Black" refer to the colors of the arcs in your screenshot.
