meyerforhire Posted September 3, 2011 Posted September 3, 2011 I'm trying to build a "smarter" insert routine for placing furniture blocks. What I mean by "smarter" is I'd like the user to be able to control, preferably by keystroke, whether to mirror the block or rotate it by a fixed angle on each depression of whatever key I decided. The problem I'm having is I don't even know how to properly "search" for help without finding mounds of nonrelevant information. The biggest issue I can't find resolution for, is being able to keep the block ghosted on my mouse throughout and having that ghosted block update with the user input until it is finaly placed. Really, the rotation could come at the end, I just want to be able to have a visible insert routine with a mirror option. What's frustrating is I know it can be done--I've seen it using a furniture vendor's proprietary ACAD applet. I have been able to take the applet apart--somewhat--but I believe what I'm looking for in this applet is LISP. I don't understand LISP all that great and I'd really like to be able to use VBA. I've been able to get small, digestible snippets of LISP to work in conjunction with VBA, but that's about it. The closest I've gotten so far, is to use several small sub routines--like: Sub BasicInsert() ThisDrawing.ModelSpace.InsertBlock InsPnt(), "TypicalD1", 1, 1, 1, Rot() End Sub Function InsPnt() As Variant Dim Pnt1 As Variant Pnt1 = ThisDrawing.Utility.GetPoint(, "Choose insertion point") InsPnt = Pnt1 End Function Function Rot() Dim rotAng As Double Dim InsPnt As Variant rotAng = ThisDrawing.Utility.GetAngle(, vbCr & "Select Angle:") End Function By closest, I mean I've figured out that I can run sub routines inside of the InsertBlock routine. Really, I don't even know if I'm on the right path with this. Another route I'm considering but don't even know how to invoke is to get VBA to replicate the live action equivalent of grabbing a block by its insertion point grip. You know, when your in ACAD and you highlight a block and then click it's insertion point grip, you now have ahold of that block until you click elsewhere in the drawing to place it. I think if I could figure that out in VBA or LISP, I could get the rest of the stuff to fall in line. Any help would be oh so greatly appreciated. Thanks! Quote
meyerforhire Posted September 6, 2011 Author Posted September 6, 2011 UPDATE: The other route I mentioned--"Another route I'm considering but don't even know how to invoke is to get VBA to replicate the live action equivalent of grabbing a block by its insertion point grip. You know, when your in ACAD and you highlight a block and then click it's insertion point grip, you now have ahold of that block until you click elsewhere in the drawing to place it. I think if I could figure that out in VBA or LISP, I could get the rest of the stuff to fall in line." This is just another way to invoke the STRETCH command, so I doubt it will be helpful. Quote
SEANT Posted September 7, 2011 Posted September 7, 2011 With regard to visual feedback, VBA is a poor programming interface. The process is not possible with just VBA, but several workarounds have been suggested. Here is one former thread where the topic was discussed: http://www.cadtutor.net/forum/showthread.php?23468 Operations requiring visual feedback are significantly more feasible in Lisp or VB.NET. Quote
meyerforhire Posted September 8, 2011 Author Posted September 8, 2011 (edited) SEANT, Thanks for the reply! Unfortunately, in the referenced post, frostrap never posted the LISP he eluded to ultimately using. Whilst waiting for a reply, I headed down another road and decided to invoke the "-insert" via lisp then selected that block via acSelectionSetLast in an attempt to use keyboard input to alter the block. However, I'm not using the utility for input, I'm attempting to run several API functions to look for what key gets pressed. I'm getting some really wild, wild things out of it--like once I press the left or right arrow keys, the block spins like a propellar and, while being very intertaining, ultimately causes a crash. I'll post the code and if you feel like picking it apart, please do. If not, it's okay, I'm just going to keep slogging until something works. Private Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As Integer Private Declare Function GetKeyboardState Lib "user32" (kbArray As KeyboardBytes) As Long Private Declare Function SetKeyboardState Lib "user32" (kbArray As KeyboardBytes) As Long Private Type KeyboardBytes kbByte(0 To 255) As Byte End Type Global Cnt As Long Sub RunRoutine() Dim objBlock As AcadBlock, objRef As AcadBlockReference, objMir As AcadBlockReference Dim objEnt As AcadEntity, entArray(0) As AcadEntity Dim FurnPath As String, blkName As String Dim SS1 As AcadSelectionSet Dim insPnt1 As Variant, BXmin As Variant, BXmax As Variant Dim insPntX(0 To 2) As Double Dim insPntY(0 To 2) As Double Dim BXul(0 To 2) As Double Dim rotAng As Double Dim retKey As Boolean Dim prsKey Dim kbArray As KeyboardBytes On Error Resume Next ThisDrawing.SelectionSets.Item("insBlock").Delete On Error GoTo 0 blkName = GetLispSym("B") FurnPath = "C:\Program Files\Autodesk\AutoCAD 2011\Support\COE_RST-FurnApps\COE_RST-FurnBlocks.dwg" If TestBlock(blkName) = True Then ThisDrawing.SendCommand blkName & vbCr ElseIf Dir(FurnPath) = "" Then Do Until Dir(FurnPath) <> "" And Right(FurnPath, 4) = ".dwg" On vbCancel GoTo 1 FurnPath = InputBox("Enter Block file path, i.e. C:\My Documents\ACAD Blocks\BlockFile.dwg", "Block File Path?") If Dir(FurnPath) = "" Then MsgBox "File Doesn't Exist, Try Again." Else End If Loop GetFurnBlock blkName, FurnPath ThisDrawing.SendCommand blkName & vbCr Else GetFurnBlock blkName, FurnPath ThisDrawing.SendCommand blkName & vbCr End If Set SS1 = ThisDrawing.SelectionSets.Add("insBlock") SS1.Select acSelectionSetLast SS1.Highlight True For Each objEnt In SS1 If TypeOf objEnt Is AcadBlockReference Then Set objRef = objEnt Set objEnt = Nothing insPnt1 = objRef.InsertionPoint insPntX(0) = insPnt1(0) + 1#: insPntX(1) = insPnt1(1): insPntX(2) = 0 insPntY(0) = insPnt1(0): insPntY(1) = insPnt1(1) + 1#: insPntY(2) = 0 Do Until retKey = True ThisDrawing.Utility.Prompt "UP=FlipUp/DOWN=FlipDown/RIGHT=+90/LEFT=-90" & vbCr For Cnt = 13 And 32 To 128 If GetAsyncKeyState(Cnt) <> 0 Then prsKey = Cnt Exit For Else End If Next Cnt Select Case prsKey Case 38 objRef.GetBoundingBox BXmin, BXmax BXul(0) = BXmin(0): BXul(1) = BXmax(1): BXul(2) = 0 Set objMir = objRef.Mirror(BXul, BXmax) objRef.Delete Set objRef = Nothing SS1.Clear Set objRef = objMir Set objMir = Nothing Set entArray(0) = objRef SS1.AddItems entArray SS1.Update Set entArray = Nothing Case 40 Set objMir = objRef.Mirror(insPnt1, insPntX) objRef.Delete Set objRef = Nothing SS1.Clear Set objRef = objMir Set objMir = Nothing Set entArray(0) = objRef SS1.AddItems entArray SS1.Update Set entArray = Nothing Case 39 rotAng = objRef.Rotation objRef.Rotate insPnt1, (rotAng + 90) Case 37 rotAng = objRef.Rotation objRef.Rotate insPnt1, (rotAng - 90) Case 13 retKey = True End Select GetKeyboardState kbArray For Cnt = 32 To 128 kbArray.kbByte(Cnt) = 0 Next Cnt SetKeyboardState kbArray Loop Set objRef = Nothing Else End If Next SS1.Clear SS1.Delete Set SS1 = Nothing 1 End Sub I know it's extremely rough, but I'm learning bunches. I think, in the near future, I will start heading down the .Net road--it's where everything is basically heading anyway. Thanks again! Edited September 8, 2011 by meyerforhire Added API Declerations Quote
