K7RDB Posted September 3, 2011 Posted September 3, 2011 This used to work, then my computer dies and AutoCad was reinstalled. I am trying to dimension some cut-outs in a 19" rack panel. I can dimension them, it shows the correct dimensions but then when I hit enter it wont save the dimensions. I've gone into DIMSTYLE and everything looks fine but I cant get this simple task to work. Any help would be much appreciated. Quote
acadesign09 Posted September 3, 2011 Posted September 3, 2011 I think you need to check the DIMENSION SETTINGS, it may help you to solve your problem. Quote
SLW210 Posted September 8, 2011 Posted September 8, 2011 Make sure the layer is not off or frozen. Quote
Arizona Posted September 8, 2011 Posted September 8, 2011 ".....then when I hit enter it wont save the dimensions...." As Nestly stated, you need to Pick a point (left click) for the dimension to be Placed. That finishes the command. If you hit enter, you are prematurly exiting the command. Quote
