This used to work, then my computer dies and AutoCad was reinstalled. I am trying to dimension some cut-outs in a 19" rack panel. I can dimension them, it shows the correct dimensions but then when I hit enter it wont save the dimensions. I've gone into DIMSTYLE and everything looks fine but I cant get this simple task to work. Any help would be much appreciated.
I think you need to check the DIMENSION SETTINGS, it may help you to solve your problem.
".....then when I hit enter it wont save the dimensions...."
As Nestly stated, you need to Pick a point (left click) for the dimension to be Placed. That finishes the command. If you hit enter, you are prematurly exiting the command.
