sha07shi Posted August 29, 2011 Posted August 29, 2011 i am new to this forum ...... i am using autocad2008, my boss wants me to draw a square 100x100mm in such a way so that if i take a print out in an A4 sheet(210x297mm) it should measure exactly 100mmx100mm wen i measure it using tape..... plz help i can't seem to figure this out ... Quote
CyberAngel Posted August 29, 2011 Posted August 29, 2011 Welcome to the forum! 1) In model space, draw your square at actual size. 2) In paper space, create a viewport at 1=1 scale. 3) Plot the layout at 1=1 scale. Quote
Dana W Posted August 29, 2011 Posted August 29, 2011 Mspace units = mm. Pspace units =mm. Select A4 as paper size. plot & viewport scale = 1:1 If your plotter is accurate, the drawing will be. The scale is full size, unles there is a typo in your post. Quote
sha07shi Posted August 31, 2011 Author Posted August 31, 2011 Thank you guys got it thank you very much ... Quote
