I have been trying to figure this out for a couple of days now. The only thing I could find is this LISP that takes the Ellipse properties and uses them to creat an arc.
When I use this, the start and end angles are not correct in the drawing. Ellipses must have been drawn in a different UCS).
I have tried to get the LISP to use the start and end points of the ellipse along with the radius and center point. For the life of me I cannot figure it out. If anyone knows how to do this please let me know.
*NOTE* Elllipses that I am trying to convert have the same minor and major radii.
Thanks in advance!!
(defun c:e2a (/ acaddoc acadms acadobj center endangle obj radius ss ssn startangle)
 (vl-load-com)
 (if
   (setq ss (ssget '((0 . "ellipse"))))
     (setq acadobj (vlax-get-acad-object))
     (setq acaddoc (vla-get-activeDocument acadobj))
     (setq acadms (vla-get-modelspace acaddoc))
     (setq ssn (ssname ss 0))
     (setq obj (vlax-ename->vla-object ssn))
     (if
obj ;(equal (vla-get-RadiusRatio obj) 1 0.0001)
  (setq radius (vla-get-MajorRadius obj))
  (setq Startangle (vla-get-Startangle obj))
  (setq Endangle (vla-get-Endangle obj))
  (setq Center (vlax-get obj 'center))
  (entdel ssn)
  (vla-addarc acadms (vlax-3d-point Center) radius Startangle Endangle)
  ) ; progn
(alert "> Ellipse objects failed to be converted")
)   ; if
     )     ; progn
   )       ; if
 )       ; defun
I am not sure that getting an arc from ellipse is possible. The arc is part of a circle.
The equation of a circle is (X-X1)^2 + (Y-Y1)^2=R^2.
The equation of an ellipse is (X^2)/(A^2) + (Y^2)/(B^2) = 1
It seems that an arc and an ellipse can only have common graphics if A = B which makes the ellipse circle....
