Convert Ellipse to Arc
Bill_Myron
I have been trying to figure this out for a couple of days now. The only thing I could find is this LISP that takes the Ellipse properties and uses them to creat an arc.
When I use this, the start and end angles are not correct in the drawing. Ellipses must have been drawn in a different UCS).
I have tried to get the LISP to use the start and end points of the ellipse along with the radius and center point. For the life of me I cannot figure it out. If anyone knows how to do this please let me know.
*NOTE* Elllipses that I am trying to convert have the same minor and major radii.
Thanks in advance!!
(defun c:e2a (/ acaddoc acadms acadobj center endangle obj radius ss ssn startangle)
(vl-load-com)
(if
(setq ss (ssget '((0 . "ellipse"))))
(setq acadobj (vlax-get-acad-object))
(setq acaddoc (vla-get-activeDocument acadobj))
(setq acadms (vla-get-modelspace acaddoc))
(setq ssn (ssname ss 0))
(setq obj (vlax-ename->vla-object ssn))
(if
obj ;(equal (vla-get-RadiusRatio obj) 1 0.0001)
(setq radius (vla-get-MajorRadius obj))
(setq Startangle (vla-get-Startangle obj))
(setq Endangle (vla-get-Endangle obj))
(setq Center (vlax-get obj 'center))
(entdel ssn)
(vla-addarc acadms (vlax-3d-point Center) radius Startangle Endangle)
) ; progn
(alert "> Ellipse objects failed to be converted")
) ; if
) ; progn
) ; if
) ; defun
[/Code]
Hi Bill,
I would be inclined to use the entmake(x) function for this task, as transference of object properties can be accomplished with a single function call.
Here is my program:
[color=GREEN];; Ellipse 2 Arc  -  Lee Mac 2011  -  www.lee-mac.com[/color]
[color=GREEN];; Converts Circular Ellipses (Axis Ratio = 1) to Circles/Arcs[/color]
([color=BLUE]defun[/color] c:e2a ( [color=BLUE]/[/color] e i s )
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] s ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color] '((0 . [color=MAROON]"ELLIPSE"[/color]) (40 . 1.0))))
       ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] s))
           ([color=BLUE]setq[/color] e ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] s ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i)))))
               ([color=BLUE]entmakex[/color]
                   ([color=BLUE]if[/color] ([color=BLUE]equal[/color] ([color=BLUE]abs[/color] ([color=BLUE]-[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 42 e)) ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 41 e)))) ([color=BLUE]+[/color] [color=BLUE]pi[/color] [color=BLUE]pi[/color]))
                       ([color=BLUE]apply[/color] '[color=BLUE]append[/color]
                           ([color=BLUE]cons[/color]
                               ([color=BLUE]list[/color]
                                   ([color=BLUE]cons[/color] 0 [color=MAROON]"CIRCLE"[/color])
                                   ([color=BLUE]cond[/color] (([color=BLUE]assoc[/color]  6 e)) ('( 6 . [color=MAROON]"BYLAYER"[/color])))
                                   ([color=BLUE]cond[/color] (([color=BLUE]assoc[/color] 39 e)) ('(39 . 0.0)))
                                   ([color=BLUE]cond[/color] (([color=BLUE]assoc[/color] 62 e)) ('(62 . 256)))
                                   ([color=BLUE]cons[/color] 10 ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 e)) 0 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 210 e))))
                                   ([color=BLUE]cons[/color] 40 ([color=BLUE]distance[/color] '(0. 0. 0.) ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 11 e))))
                               ([color=BLUE]mapcar[/color]
                                   ([color=BLUE]function[/color]
                                       ([color=BLUE]lambda[/color] ( x )
                                           ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]member[/color] ([color=BLUE]car[/color] x) '(-1 0 5 6 10 11 39 40 41 42 62 100 330)))
                                               ([color=BLUE]list[/color] x)
                                   e
                                   ([color=BLUE]cons[/color] 0 [color=MAROON]"ARC"[/color])
                                   ([color=BLUE]cons[/color] 50 ([color=BLUE]+[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 41 e)) ([color=BLUE]angle[/color] '(0. 0. 0.) ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 11 e)) 0 1))))
                                   ([color=BLUE]cons[/color] 51 ([color=BLUE]+[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 42 e)) ([color=BLUE]angle[/color] '(0. 0. 0.) ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 11 e)) 0 1))))
                                   e
               ([color=BLUE]entdel[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] -1 e)))
   ([color=BLUE]princ[/color])
Edited by Lee Mac
Thanks for the reply!
I tried your program, and it ends up doing the same as what I had. It replaces the ellipse with an arc based on the start and end angles, causeing the arc to be created in a different location than where the ellipse currently is. The properties of the new arc and the old Ellipse have the same start and end angles, but the arc is drawn as if it was rotated. I hope that makes sense.
If the program could use the start and end points instead of the angles, I think it would work.
Lee Mac you are a genius! It works amazing. I cant thank you enough. You saved me lots time on here.
Thanks again!!
  • 3 years later...
Just started using this lisp in 2014.
For some reason it will not select any ellipse. I suspect it has to do with how 2014 creates the ellipse.
Wonder if anyone else has encountered this, or if they have a different way to convert ellipses into arcs?
Lee's code is fine, but I suspect that you are attempting to select real ellipse and not circular one - in selection filter that follows (ssget) function it was explicitly written that ratio between "small" and "big" ellipse radius is 1.0 which means that ellipse must be circular in order for (ssget) function to accept selecting entities filtered by written filter statement that follows inside (ssget) function...
Perhaps it may be some setting I have set.
The ellipse are circular with a radius ratio of 1.
Attached is a drawing that will not allow me to select the ellipses with the lisp.
Ellipse.dwg
Thank you for attaching the sample drawing.
The issue is that, although very close to being circular, the ellipse axis ratio is in fact not quite equal to 1.0.
You can verify this by using the following program to retrieve the axis ratio for a selected ellipse:
(defun c:eratio ( / e )
   (while
       (and (setq e (car (entsel "\nSelect ellipse: ")))
            (= "ELLIPSE" (cdr (assoc 0 (entget e))))
       (princ (strcat "\nEllipse ratio: " (rtos (cdr (assoc 40 (entget e))) 2 15)))
Testing the program with a few ellipses from your drawing yields the following results:
Select ellipse:
Ellipse ratio: 0.999999532781626
Select ellipse:
Ellipse ratio: 0.999999532795758
Select ellipse:
Ellipse ratio: 0.999999532786339
Select ellipse:
Ellipse ratio: 0.999999532749180
Select ellipse:
Ellipse ratio: 0.999999532857222
The following code is a modification of the Ellipse to Arc program published on my site here, to incorporate some tolerance into the ellipse ratio filter:
[color=GREEN];;-------------------=={ Ellipse to Arc }==-------------------;;[/color]
[color=GREEN];;                                                            ;;[/color]
[color=GREEN];;  Converts circular Ellipses & Elliptical Arcs (i.e. for    ;;[/color]
[color=GREEN];;  which the Ellipse Axis Ratio = 1.0) to Circles & Arcs,    ;;[/color]
[color=GREEN];;  whilst retaining all original properties. Works with      ;;[/color]
[color=GREEN];;  Ellipses & Elliptical Arcs constructed in any UCS.        ;;[/color]
[color=GREEN];;------------------------------------------------------------;;[/color]
[color=GREEN];;  Author: Lee Mac, Copyright © 2013 - www.lee-mac.com       ;;[/color]
([color=BLUE]defun[/color] c:e2a ( [color=BLUE]/[/color] a b c e i m p q r s u v z )
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] s ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color] '((0 . [color=MAROON]"ELLIPSE"[/color]) (-4 . [color=MAROON]">="[/color]) (40 . 0.9999) (-4 . [color=MAROON]"<="[/color]) (40 . 1.0001))))
                 z ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 210 e))
                 c ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 e)) 0 z)
                 p ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 11 e)) 0 z)
                 a ([color=BLUE]distance[/color] '(0.0 0.0) p)
                 b ([color=BLUE]*[/color] a ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 40 e)))
                 r ([color=BLUE]angle[/color] '(0.0 0.0) p)
                 u ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 41 e))
                 v ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 42 e))
                 m ([color=BLUE]list[/color] ([color=BLUE]list[/color] ([color=BLUE]cos[/color] r) ([color=BLUE]-[/color] ([color=BLUE]sin[/color] r))) ([color=BLUE]list[/color] ([color=BLUE]sin[/color] r) ([color=BLUE]cos[/color] r)))
                 p ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] c (mxv m ([color=BLUE]list[/color] ([color=BLUE]*[/color] a ([color=BLUE]cos[/color] u)) ([color=BLUE]*[/color] b ([color=BLUE]sin[/color] u)))))
                 q ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] c (mxv m ([color=BLUE]list[/color] ([color=BLUE]*[/color] a ([color=BLUE]cos[/color] v)) ([color=BLUE]*[/color] b ([color=BLUE]sin[/color] v)))))
               ([color=BLUE]if[/color] ([color=BLUE]equal[/color] p q 1e-
                   ([color=BLUE]entmake[/color]
                       ([color=BLUE]cons[/color] '(0 . [color=MAROON]"CIRCLE"[/color])
                           ([color=BLUE]append[/color] (LM:defaultprops e)
                                   ([color=BLUE]cons[/color]  010 c)
                                   ([color=BLUE]cons[/color]  040 a)
                       ([color=BLUE]cons[/color] '(0 . [color=MAROON]"ARC"[/color])
                                   ([color=BLUE]cons[/color]  050 ([color=BLUE]angle[/color] c p))
                                   ([color=BLUE]cons[/color]  051 ([color=BLUE]angle[/color] c q))
[color=GREEN];; Default Properties  -  Lee Mac[/color]
[color=GREEN];; Returns a list of DXF properties for the supplied DXF data,[/color]
[color=GREEN];; substituting default values for absent DXF groups[/color]
([color=BLUE]defun[/color] LM:defaultprops ( elist )
           ([color=BLUE]lambda[/color] ( pair )
               ([color=BLUE]cond[/color] (([color=BLUE]assoc[/color] ([color=BLUE]car[/color] pair) elist)) ( pair ))
           (008 . [color=MAROON]"0"[/color])
           (006 . [color=MAROON]"BYLAYER"[/color])
           (039 . 0.0)
           (062 . 256)
           (048 . 1.0)
           (370 . -1)
[color=GREEN];; Matrix x Vector  -  Vladimir Nesterovsky[/color]
[color=GREEN];; Args: m - nxn matrix, v - vector in R^n[/color]
([color=BLUE]defun[/color] mxv ( m v )
   ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( r ) ([color=BLUE]apply[/color] '[color=BLUE]+[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]*[/color] r v))) m)
I agree with Bill.... the program is not recognizing the ellipse.... so it is not getting selected.
i understand this is an old thread..... maybe the forum has shifted to another thread... it will be useful to convert ellipses to mathematically accurate circles / arcs
What is the axis ratio of your ellipses? (use the above program to check this)
  • 2 years later...
