DANIEL Posted August 24, 2011 Posted August 24, 2011 (edited) can you get into the blocks through the refedit command? Edited August 24, 2011 by DANIEL got my commands backwards Quote
DNK Posted August 24, 2011 Posted August 24, 2011 Have you successfully Blockedited the current file you are working with? Can you post the file so a third party can eliminate it as the problem? As a side thought, verify your support file paths are valid. Quote
DO2908 Posted August 24, 2011 Author Posted August 24, 2011 A virus that affects only 2 computers in the company and that blocks only the block editor?? :S So weird... Quote
DO2908 Posted August 24, 2011 Author Posted August 24, 2011 DANIEL said: can you get into the blocks through the refedit command? Yes but I want to access the options for dynamic blocks. Quote
DO2908 Posted August 24, 2011 Author Posted August 24, 2011 DNK said: Have you successfully Blockedited the current file you are working with? Can you post the file so a third party can eliminate it as the problem? As a side thought, verify your support file paths are valid. You mean opening the file from another autocad on another computer? Yes I tried that and I was able to enter the block editor (2012). Which makes me think the problem comes from the computer or the 2011 version we are using. What are support file paths? Quote
DANIEL Posted August 24, 2011 Posted August 24, 2011 DO2908 said: You mean opening the file from another autocad on another computer? Yes I tried that and I was able to enter the block editor (2012). Which makes me think the problem comes from the computer or the 2011 version we are using.What are support file paths? go to tools, then down to options, then select the file tab, there is a heading called support file paths, compare them to a system that is working Quote
DO2908 Posted August 24, 2011 Author Posted August 24, 2011 The entries are the same. Someone on another forum mentionned undefined block editor. Could my BEDIT have somehow been undefined? Quote
SLW210 Posted August 24, 2011 Posted August 24, 2011 Are you running some Registry Cleaners/Editors? Quote
SLW210 Posted August 25, 2011 Posted August 25, 2011 DO2908 said: The entries are the same.Someone on another forum mentionned undefined block editor. Could my BEDIT have somehow been undefined? Yes, but ._BEDIT should work if that were the case. Check with your IT department and see what they have been running that could be affecting your Registry/AutoCAD. Is BEDIT the only thing not working? Quote
DO2908 Posted August 25, 2011 Author Posted August 25, 2011 Yes BEDIT seems to be the only thing missing. We thought about updating its version from 2011 to 2012. I hope this solves the problem... We currently have both versions running in the office and the BEDIT problem affects only the 2011 one. Quote
DNK Posted August 25, 2011 Posted August 25, 2011 How about writing the block to a file, then opening that file with 2011. If I recall, when you open a dynamic block, it automatically opens in the block editor. Quote
DO2908 Posted August 25, 2011 Author Posted August 25, 2011 Autocad still gives me an unknown command. Quote
bogdan823 Posted January 14, 2015 Posted January 14, 2015 DO2908 said: Hi, I am currently using Autocad 2011 and my block editor suddenly won't open this morning... I have tried the blockeditlock to open it but nothing happens when I change the setting (0 or 1).Have anyone ever had a problem like this one before? Please help! PICKFIRS must be 1 Quote
Dana W Posted January 14, 2015 Posted January 14, 2015 bogdan823 said: PICKFIRS must be 1Number one, the thread is almost four years old, Number two, your suggestion is irrelevant to the issue, number three, you spelled it wrong. Quote
SLW210 Posted January 14, 2015 Posted January 14, 2015 Since this was brought back up... As it turns out AutoCAD 2011 had a Hotfix or Service pack that came out at some point that fixes this, so for future AutoCAD 2011 users that run into this problem, get all the hotfixes and updates. Quote
DRBLA Posted April 1, 2024 Posted April 1, 2024 I realize this is an older thread but I was experiencing this same issue on a new computer when setting up my user preferences on AutoCAD 2023. The solution that worked for me was to go into Options > User Preferences tab > Windows Standard Behavior. Then check Double click editing and Shortcut menus in drawing area. Click on the "Right-click Customization" tab. When that window opens, I have the following items/buttons set: Default Mode = Repeat Last Command. Edit Mode = Shortcut Menu. Command Mode = ENTER. Hope this helps someone! Quote
