Hello,
Iàm looking for a lisp that can create 4 layer group filters. Group1 = installation,
group2 =bis1, group3 =bis2 and group4 =bis3 at once.
Also looking for a lisp to turn a layer group filter on/off or freeze/thaw or viewport freeze/thaw.
Many thanks,
Jaap
(vl-load-com)
;;; Create layer "Lay1" "Lay2" "Lay3"
(mapcar '(lambda(lay)
 (vla-add(vla-get-layers(vla-get-activedocument (vlax-get-acad-object))) lay)
 (list "Lay1" "Lay2" "Lay3")
;;; Add group filter text
(vva-Layer-GroupFilter-Make "installation")
(vva-Layer-GroupFilter-Make "bis1")
(vva-Layer-GroupFilter-Make "bis2")
(vva-Layer-GroupFilter-Make "bis3")
;;; Add Layer to Group Filter
(vva-Layer-GroupFilter-Layer-add "installation" '("Lay1" "Lay2") t)
(vva-Layer-GroupFilter-Layer-add "bis1" '("Lay1" "Lay2" "Lay3") t)
(vva-Layer-GroupFilter-Layer-add "bis2" '("0" "Lay1") t)
Function (vva-Layer-GroupFilter-getLayerList) returns a list of layers which belong to the filter
;; ! Returns : List of Lists ((FilterName1 LayerName1 LayerName2 ... LayerNameN) ... (FilterNameN LayerName1 LayerName2 ... LayerNameN))
;; (("Group filter2" "Lay1" "Lay2") ("Group filter2" "Lay1"))
knowing the names of layers, you can programmatically set the properties you want them.
layerFilter.lsp
from this thread to learn that command _-layer has the option to "_filter"
Thanks..............but wat is the command for runnung the lisp? iàm not so into lisp.
I`ve already made a script with -layer/filter option. And it works. I only can`t find the awnser to turn groups on or off with a script or lisp. Wel i keep on searching on the www.
pmxcad
Need some functions from #2
(defun on_off_layer_by_groupFilterName (groupFilterName what)
 ;;;groupFilterName - name of Layer Group Filter.  Case sensitive
 ;;; what - options command _-layer. "_on" or "_off"
 ;;; (setq groupFilterName "installation")
 ;;; USE (on_off_layer_by_groupFilterName "installation" "_on")
 ;;; USE (on_off_layer_by_groupFilterName "installation" "_off")
 ((lambda(lst / lays)
     (setq lays(apply 'strcat (mapcar '(lambda(x)(strcat x ",")) lst)))
     (command "_-LAYER" what lays "")
   (cdr (assoc groupFilterName (vva-Layer-GroupFilter-getLayerList)))
Use
(on_off_layer_by_groupFilterName "installation" "_off") ;;; Turn off all layers of the Gruopfilter "installation"
(on_off_layer_by_groupFilterName "installation" "_on") ;;; Turn on all layers of the Gruopfilter "installation"
VVA,
There's no need to invoke -LAYER command (multiple times?), see this thread. ;)
Also, same problem as in other 'create layer' thread:
There's no need to repeatedly call the Layers Collection, nor is it considered "Best Practice" to attempt adding layers that already exist.
