Radzha Posted August 22, 2011 Share Posted August 22, 2011 Hi all It has been a long time since my last post but here I am again. I have some problems with sheet templates (or is it drawing templates ) here is what I need to have: 1) drawing template with 1 sheet when new drawing is created. 2) when I add second, third and more sheets, it should have same title block. 3) all info (author, date, number and other notes) should be the same as on first sheet automatically. 4) changing info on first sheet title block with property tab, properties should change on other sheet also. How can I do that? I have some similar templates from our SW reseller tech guy, but it is not enough. though I can't find what he did and how. Would like to create some templates of my own. any ideas? Quote Link to comment Share on other sites More sharing options...
rdharvey Posted August 22, 2011 Share Posted August 22, 2011 There are plenty video tutorials on youtube and around the web Quote Link to comment Share on other sites More sharing options...
Radzha Posted August 23, 2011 Author Share Posted August 23, 2011 Thanks rdharvey. Found it somehow myself. The main problem is all (at least what i have found) tutorials show how to make single sheet, but never talk about other sheets. It was the problem and I was confused because drawing template at my work was made so that first and other sheets were a bit different. However I found the way. Configure first sheet as you wish and save SHEET FORMAT TEMPLATE. Quote Link to comment Share on other sites More sharing options...
