I have a dwg sent to me i think it was in metric they provided no scale
I need to have it in units of feet, inches.
one distance that came with the dwg shows as 111 996
another dim that i know from another dwg at scale of 1=20
measures about 24'-6 that dim shows as 7-5/8 not sure what
to do that will make the dwg work. any suggestions.
1 Meter = 39.37008 inches If you want 1 AutoCAD unit to = 1 inch scale by 39.3708
If you received the drawing as a .dwg, post the file so we can have a look.
Received the *.dwg file?
Why not change the dimstyle and see what you find?
(dim below showing the cut length for the 2" pipe).
I work mostly with inches, three decimal places but, have to provide
metric to some of my out of the USA clients.
