change layer while editing (copy, move, rotate)
What I want to do is to combine two commands, editing (copy, move, rotate) and change layer.
I think I have seen this before somewhere but can't find now.
Will be happy if you could guide me.
Nobody wants to reply to this post?
Or a lisp which simply copies to the current layer instead of having to pick an entity on the target layer, or select it's name from the dialog. Just make sure you use Enter/Space to stop the copy instead of Esc when you use the Multiple option:
(defun c:Copy2CurLay (/ ss el en)
 (setq el (entlast))
 (if (setq ss (ssget))
     (command "._COPY" ss "")
     (while (= (logand (getvar 'CmdActive) 1) 1) (command pause))
     (setq en (entnext el))
     (while en
       (entmod (list (cons -1 en) (cons 8 (getvar 'CLayer))))
       (setq en (entnext en))
