monk Posted August 11, 2011 Posted August 11, 2011 Hello, I have a ventilation attenuator I would like to compile into a dynamic block. At the moment I have the files in folder (Folder name is length) I wish to create a dynamic block per length. Is there and easy way to compile this without having to copy and paste from the other files? Quote
qball Posted August 12, 2011 Posted August 12, 2011 I doubt it. How many files / lengths? Can you post the drawing? Quote
monk Posted August 15, 2011 Author Posted August 15, 2011 These are two files. I have got 300,450,600,750,900,1200,1500,1800,2100,2400,2700,3000 Lengths with probably 30 odd different widths in each length. I tried to create a dynamic block with stretches and things but with no luck. So I though just have a block for each length with a visibility state to select width. But was hoping there would be an easier way to compile it! 125x300_att.dwg 1700x2400_att.dwg Quote
dbroada Posted August 15, 2011 Posted August 15, 2011 in what way did you have no luck with stretches? Can you post what you have? Quote
monk Posted August 15, 2011 Author Posted August 15, 2011 It was the middle 'curvy' line that wouldn't stretch not sure how to get it to look right? Some sort of scaling or array? Quote
dbroada Posted August 15, 2011 Posted August 15, 2011 (edited) I was afraid you would say that. It may be possible to add separate X & Y scales to it linked to the distance parameters. Don't forget that you don't have to scale 1:1, it can be 0.734:1 if that helps. Ignore the above. Typed before testing. This is the best I could do. 125x300_att-2.dwg Edited August 15, 2011 by dbroada to correct rubbish suggestion Quote
monk Posted August 15, 2011 Author Posted August 15, 2011 I will try using X / Y scales later when I get a chance. Thanks Quote
dbroada Posted August 15, 2011 Posted August 15, 2011 I typed my correction too slow. X-Y scaling doesn't work in 2008. You may have more luck with 2011 though. Quote
monk Posted August 15, 2011 Author Posted August 15, 2011 Difficult to explain without illustration and I don't have the time right now. But it would perhaps be good to have the edges of the 'swirly' line a set distance from the edge of the attenuator. I have not played with parametric constraints within blocks as yet but perhaps scaling in the X and Y with constraints? Quote
dbroada Posted August 15, 2011 Posted August 15, 2011 parametric constraints may well be the best way forwards - but they aren't available on my version of AutoCAD. Quote
monk Posted August 15, 2011 Author Posted August 15, 2011 I shall post my solution / findings if i get that far. Trying to standardise my M&E dept. But also trying to make it easier for people to use. So putting in the legwork creating dynamic blocks, then placing them on palettes so they insert on a specific layer. Getting there! Quote
qball Posted August 22, 2011 Posted August 22, 2011 you might be able to stretch the squiggly lines with a Chained Action. But the radii of the curves would be unchanged. So I don't know if it has to be that specific. Quote
monk Posted August 22, 2011 Author Posted August 22, 2011 The radii is not specific it is really just an indicative line. Not played much with chained action would you be able to explain a bit more? Quote
qball Posted August 22, 2011 Posted August 22, 2011 scratch that. If your distance is a List rather than an increment, it gets difficult. Best to explore Constraints as Dave mentioned. edit: Really hard to read, but D1 = 275, D2 = 50/275*D1... and so forth. I have not used a lot of Constraints, but I understand when you use them in Block Editor they should act similar to Parameters and Actions. Quote
monk Posted August 22, 2011 Author Posted August 22, 2011 Not restricted to lengths if the block scales correctly in the X and Y then i can snap it to a duct. I will have a look now. Quote
