amelia283 Posted August 10, 2011 Share Posted August 10, 2011 Hi All - I am new to Civil 3D and I have just taken over a road job. I had to change the alignment of part of the road section, which I succeed in doing. However, now that I have changed the center line of the road all the cross sections from the change forward are missing. When I look at my alignment gird view all the sections are there and when I click on the line it goes from beginning to end. Any ideas on how to convince the software to print cross sections from beginning to end. Thanks! Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted August 11, 2011 Share Posted August 11, 2011 Just to eliminate the obvious, did you rebuild your corridor? If you have section lines, did you move them to the new location? Quote Link to comment Share on other sites More sharing options...
amelia283 Posted August 11, 2011 Author Share Posted August 11, 2011 I figured out the problem! Some how regions of my corridor had been screwed up. Once I got into the corridor properties and got them all working together I got the sections back. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted August 11, 2011 Share Posted August 11, 2011 Congratulations! and welcome to the forum! Quote Link to comment Share on other sites More sharing options...
