nlao Posted August 10, 2011 Share Posted August 10, 2011 Hi Please note this is not the age old questions of model vs paperspace. I am having problems getting my head around why this particular drawing refuses to display paperspace objects that have broken linetypes, hidden, dashed etc are all displayed the same, as continuous. I can copy the drawing entities to another file and they display fine, what is even stranger is that they print fine. I have run through all the various LTSCALE commands, CE, MS, PS etc. I then thought it was a visual style problem but apparently that can't be it as they are not possible to be applied to Paperspace. At that point I thought about MEASUREMENT and that sort of thing. None of these make the linetypes display properly. I am at a loss to what it might be!! Any ideas of which setting has been thrown in this file? Thanks in advance. Test.dwg Quote Link to comment Share on other sites More sharing options...
Organic Posted August 10, 2011 Share Posted August 10, 2011 I took a look at it althoguh are not sure either. I couldn't work out why I couldn't change the linetype scales in the properties pane as if they were locked somehow. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 10, 2011 Share Posted August 10, 2011 Something is wrong with your drawing, just wblock what you need to a new drawing. I -PURGE and got a lot of RegApps, but still didn't fix it. My cursor froze dead in the center of Model space when I tried to paste the lines into Model. I wouldn't worry to much about trying to figure this out, just make a new drawing. Quote Link to comment Share on other sites More sharing options...
