Hello Mircea,
Can you help me to use (Polar point angle distance) to change text spacing with your code
(foreach TextLabel (list (list Text1st Layer1st) (list Text2nd Layer2nd) (list Text3rd Layer3rd)) (command "_TEXT") (if InsertionPoint (setq InsertionPoint (command InsertionPoint TextHeight TextAngle)) (command "")) (command (car TextLabel) "_CHPROP" (entlast) "" "_LA" (cadr TextLabel) "") )
  • Replies 23
  • fathihvac
    7
  • Lt Dan's legs
    7
  • MSasu
    4
  • BlackBox
    3
Posted Images
(foreach x (list (cons 1st_text_line 1st_text_layer)(cons 2st_text_line 2st_text_layer)(cons 3st_text_line 3st_text_layer))
 (command "_.text"
   (setq insertionpoint
     (if insertionpoint
       (polar insertionpoint ;starting point
         (* pi 1.5)          ;angle away from starting point [angle expressed in radians]
         4.                  ;distance away from starting point
       (list 0. 0. 0.)
   "3"  ;text height
   "0" ;text rotation
   (car x)
 (setq e (entget (entlast)))
 (entmod (subst (cons 8 (cdr x))(assoc 8 e) e))
__Edit__
Converting to Radians
(cvunit 90 "degrees" "radians")
(* pi 0.5)
a popular way
(defun dtr ( degrees )
 (* pi (/ degrees 180.0))
(dtr 90.)
all three methods will return 1.5708 (90 degrees in radians).
Edited by Lt Dan's legs
Hello Lt Dan's legs,
The following error occured
Select insertion point : ; error: bad DXF group: (8 nil)
 (foreach x [color=red][b](list (cons "1st line of text" "0")(cons "2nd line of text" "Defpoints"))[/b][/color]
__EDIT__
also, make sure you turn your osnap off or use "non" before the insertionpoint within the command call
example:
(command "_.text" [b][color=red]"_non"
[/color][/b]    (setq insertionpoint ;and so on
