change length of layer control dropdown in toolbar
Hah..... I found FixCombos and I've tested it in 2005. I'm not sure if I'm brave enough to try it in 2011 since it stopped being developed ~2006. I think this is probably the same thing that QuikPix does.
  • Replies 51
  • BlackBox
    18
  • nestly
    15
  • designerstuart
    11
  • Ollie8974
    4
Posted Images
I'll test 2011... post or provide linky? :)
After I thought about it a bit, I decided simply loading an ARX shouldn't hurt anything, (fingers crossed) so I tried it in 2011, and it failed.
cxfixcombos16.arx is incompatible with this version of AutoCAD.
AcRxDynamicLinker failed to load 'c:\autocad2011 support
files\lisps\cxfixcombos16.arx'
C:\Program Files\Autodesk\AutoCAD 2011\acad.exeUnable to load CxFixCombos16.arx
file.
I don't know anything about programming, but perhaps you can work some magic on the code. http://www.activedwg.com/html/Downloads.php
Also FixCombos doesn't just make the layer list wider, it also makes it longer so there's less scrolling.
Sadly, no. There is nothing I can do, given that the file is compiled to ARX (C++).
ARX (C++) API Development is version specific (read Version=File format, as I understand it).The 16 in the file name is representative of the version(s) the ARX supports (i.e., R16.0, R16.1, R16.2, etc.).
Seems like there should be a magic arx update tool
Seeing how I'm a dinosaur and all, who loves his Layer and Properties toolbar, I may end up paying the $30 for QuikPiK
This just in from Autodesk Labs:
Wingardium le[t this outdated ARX R16.x filemagically become compatible with R17.* and R18.* versions]a!"
Nope, no workie... Maybe in the next AutoCAD version!?
thanks for perservering guys..... i tried it too:
CxFixCombos15.arx is incompatible with this version of AutoCAD.
AcRxDynamicLinker failed to load 'C:\AUTOCAD FILES\CxFixCombos15.arx'
C:\Program Files\AutoCAD Architecture 2009\acad.exeUnable to load
CxFixCombos15.arx file.
Someone can update/re-write that ARX for more current versions like the guy that's selling the add-on did. Maybe repost this topic in the NET, ObjectARX, and VBA forum where all the brainiacs hang out.
RenderMan, You may be correct, I don't have 2009 to test, but just to clarify, are you trying to add the Toolbar layer control, or the Ribbon Layer List/dropdown?
Demo -->
so we have been given an upgrade to 2010 - nestly thanks so much for the vid i followed it and you've sorted it!
Glad you found that useful, but I'd rather like to find an answer to your original request because it's much nicer to have a compact layer tool that only expands length when the dropdown list is activated.
I'm still holding out hope that those VBA guys will come through. 8)
  • 3 years later...
I have joined this forum for the sole purpose of answering your question!
In AutoCAD 2015 (I use LT), use the command
QUICKCUI,
to bring up this menu:
The find the Home Layers area under
All Customization Files
>Ribbon
>Home 2d
>Home Layers
Then click on the Layer dropdown box in the top right Panel Preview to get:
And change the minimum width to a higher number- I picked 500!
DONE.
BOOM.
ROASTED.
:D
