duckndon Posted August 2, 2011 Posted August 2, 2011 When I click in the layer manager, I get the following message. "Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue. Index -1 does not have a value" Then, under details, it says "Application does not support just-in-time (JIT) debugging" The weird thing is that I was just in this drawing for about half of the day with no problem. Please help! Running Civil 3D 2010. Quote
sinc Posted August 3, 2011 Posted August 3, 2011 This is a known problem that was never fixed. Sometimes you can clear it up by closing and reopening the Layer Manager. If that doesn't work, killing and restarting C3D should clear it up. Quote
