Breaking Dimesion extension lines
I was wondering if there was a way to break dimension extension lines around other dimension lines??
Similar to the picture below.
Can you clarify please which CAD is your question referring? It is posted in SolidWorks section and you profile states AutoCAD. Thank you.
Regards,
Mircea
Sorry about that. My question refers to SolidWorks. I predominately use AutoCad, but i have recently started using Solidworks
AutoCAD = 'DIMBREAK' command.
Thanks for the reply, but my question refers to if this is possible in SolidWorks??
when the dimension property tab is open there are 3 sections that you can tab to. Value, Leaders, Other. On the Leader section there is a box that says Break Lines. If you check that box you can do this. Hopefully this picture explains that a little better :)
