Rhayes Posted October 9, 2008 Posted October 9, 2008 How do I get a curtain wall to miter at the corners.??? Quote
Noahma Posted October 9, 2008 Posted October 9, 2008 turn off the frame on the corner you are trying to miter, and then select the walls and choose to miter, you will select the two walls and it should figure out the miter angle. if you you can manualy set that miter angle as well. Quote
