kpo101 Posted August 2, 2011 Posted August 2, 2011 I opened my Autocad 2009 after a power went off on me and my command line box reappeared like the attached drawing (the arrow points to the box). Can anyone tell me if this is something that just happens or is there a fix? Quote
BlackBox Posted August 2, 2011 Posted August 2, 2011 (edited) I'm not sure what startup switches are included in your application icon's target path, but this sounds like a workspace issue. If you have a named workspace, then it will appear in the list produced by left clicking the little "gear" icon in the bottom right of your application window. If you do not have a named workspace, this is a great example of why you *should* have one (or more). Hope this helps! Edited August 2, 2011 by BlackBox Quote
kpo101 Posted August 2, 2011 Author Posted August 2, 2011 Thanks for the help RenderMan, I use autocad 2011 as my main software and I do have named workspaces. I just use 2009 for general rendering of parts or sorts and for play to get a project ready for waterjet cutouts. Again thanks. Quote
