ok this is what i need...
i need to draw lines that represent pipes that the lisp command asks me the size and that effects the thickness of the pipe. it also asks me the start and end of the pipe. it's a thick dashed line that has has line at the top and bottom. it looks like this:
i already have the lisp command for this much, but what i need added to it is a flow arrow. inside the line i need an arrow every so often, to represent the water flow. thanks in advance for your help. if anyone needs the original lisp file just let me know.
Edit: or is this even doable?
