cldryden Posted May 31, 2006 Posted May 31, 2006 Hi Folks, Is there a way to open more than one acad drawing without having to open multiple acad windows? Sort of like word. You only have one window open and you can toggle between many files. I have acad 2004. Thanks a ton Quote
LSR Posted May 31, 2006 Posted May 31, 2006 Yes, you can open more than one drawing in one Autocad session. To toggle from one drawing to another use CTRL+TAB button in your keyboard. Or use your mouse and click the Autocad WINDOW pull down menu to see your drawings, click to view it. LSR Quote
cldryden Posted May 31, 2006 Author Posted May 31, 2006 I found this on the cad forum, and have installed it but not sure if it is working. I do not see a drawing tab for multiple drawings, but at least when I go to open a new drawing it does not make me close a previous one. And the alt tab thing didn't work. http://www.caelink.com/drawing_tabs.htm Quote
LSR Posted May 31, 2006 Posted May 31, 2006 The reason you cannot open multiple drawings is because your TASKBAR variable is set to 0 (zero). Set your taskbar variable to 1 (one) to display multiple drawings. Multiple display in Autocad has been around for while, you do not need to install anything. LSR Quote
cldryden Posted May 31, 2006 Author Posted May 31, 2006 How do I change the Task bar setting from 1 to zero? Quote
tzframpton Posted May 31, 2006 Posted May 31, 2006 omg... lol, type TASKBAR in the command line, then you press 0 then hit Enter. it's default is 0. change it to 1 to let you view multiple drawings. Quote
tzframpton Posted May 31, 2006 Posted May 31, 2006 btw, i just installed that MultipleTabs extension for AutoCAD, man that is nice. i'm liking that.... lol, i swear. learn something new every day here, no matter what. lol Quote
cldryden Posted May 31, 2006 Author Posted May 31, 2006 Hi there, Taskbar in the command line is not working. Any other suggestions? Quote
tzframpton Posted May 31, 2006 Posted May 31, 2006 you typed TASKBAR in the command line and pressed enter? it's in ACAD 2004 right? press F1 and search TASKBAR to see if it's in Help. Quote
cldryden Posted May 31, 2006 Author Posted May 31, 2006 ok, so, I have acad land desktop 2004 with all kinds of extensions, survey, map, civil. In the tools/options/system under the general options there is a command that can be clicked on and off for single drawing compatibility mode. typically you can click it on and off, but mine is unhighlighted and selected. It won't let me deselect it. I think this has alot to do with it. and yes I pressed enter after I typed taskbar. hee hee I also looked under help and the taskbar doesn't show up. Quote
LSR Posted May 31, 2006 Posted May 31, 2006 Here's another thought, I know Autocad intruduce multiple opening of drawings since 2000. Check your acad 2004 for variable called SDI (Sinlge Doc. Interface) the setting are 0 (zero) for mutiple; 1 for single; and then theres 2 and 3. Play around with it, see what happen. LSR Quote
cldryden Posted May 31, 2006 Author Posted May 31, 2006 Something is messed up. I did the SDI in the command line and it stated that I can select only 0 or 1. it is currently set at 3. I tried to type all numbers I could and it wouldn't let me change it. not 1 not 0 not even 3. So now I am left with going to tools/options/system and the general options box within system and selecting the single drawing compatibility mode. but unfortunately it is not highlighted. I cannot select it to have it deselected. Ugghh! I think this is where my problem is. I can't change it. HELP! Quote
tzframpton Posted May 31, 2006 Posted May 31, 2006 Maybe the problem is you don't have vanilla AutoCAD. dont you have a special version? Land Desktop or something? I wonder if that's the issue here. lol Quote
LSR Posted May 31, 2006 Posted May 31, 2006 3 denote "User disable multiple document environment and the user also loaded an application that doesn't support multiple document interface." I don't know what else to say, but keep searching. LSR Quote
LSR Posted May 31, 2006 Posted May 31, 2006 Here is your situation http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2888208&linkID=2475507 You're out of luck. LSR Quote
victor_olimpiu Posted September 27, 2011 Posted September 27, 2011 hy, i have the same problem, and i've tried the trick with sdi and taskbar , and i got nothing... i use autocad 2006 if matter. do you guys know anything else that could work ? pls:( Quote
Jack_O'neill Posted September 27, 2011 Posted September 27, 2011 Welcome to the forum victor. Just thought I'd let you know, if you don't get much of a response to your post, you dug up a thread from 2006. If you are using IE in compatibility mode, it won't show the header for some reason. If you force it out of compatibility mode or use a different browser, you can see the date and time of the post you are responding to in the dark blue bar at the upper left of the post, above where the poster's name appears. New information is always a good thing, and questions are always helpful. I'm away from my cad machines right now or I'd take a look at my 07 machine and see how it's set. When I get back home later I'll take a look and see if I can find you an answer, or maybe someone else will between now and then. Quote
Jack_O'neill Posted September 28, 2011 Posted September 28, 2011 OK, this is a screen shot from 2007, and your profile says you use 2006 but it should be close to the same. Take the check out of that "single compatibility mode" box and you should be good to go. Quote
