harilalmn Posted July 28, 2011 Share Posted July 28, 2011 Hi All, I want to make a lisp program to add prefix/suffix to all attributes of a selected block. Say, what I want to add is "(W1)". If the block has two attributes and if the attributes have their values 12134 and 23564, it should become 12134 (W1) and 23564 (W1) This process has to be looped so as to enable editing of multiple blocks one after the other. So far I have this; (defun c:w1() (setq n 1) (while (> n 0) (setq ent (car (entsel "Select Block:"))) ;This is where I am stuck. This is where I need to edit the attributes );While );Function Please help... Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 28, 2011 Share Posted July 28, 2011 Consider stepping through a filtered selection set of the desired, attributed blocks. Then step through the attributes (as a list) and check for the desired prefix/suffix in the textstring. If not present, add accordingly. Quote Link to comment Share on other sites More sharing options...
David Bethel Posted July 28, 2011 Share Posted July 28, 2011 (edited) Maybe: [b][color=BLACK]([/color][/b]defun c:addstr [b][color=FUCHSIA]([/color][/b]/ atype ns ss en ed an ad av nv[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1 [color=#2f4f4f]"Suffix Prefix"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq atype [b][color=NAVY]([/color][/b]getkword [color=#2f4f4f]"\nAdd Suffix or Prefix [b][color=MAROON]([/color][/b]S/P[b][color=MAROON])[/color][/b]: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq ns [b][color=NAVY]([/color][/b]getstring t [color=#2f4f4f]"\nString To Add: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"INSERT"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]66 . 1[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] an [b][color=GREEN]([/color][/b]entnext en[b][color=GREEN])[/color][/b] ad [b][color=GREEN]([/color][/b]entget an[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]while [b][color=GREEN]([/color][/b]/= [color=#2f4f4f]"SEQEND"[/color] [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 0 ad[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]setq av [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 1 ad[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] nv [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]= atype [color=#2f4f4f]"Prefix"[/color][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]strcat ns av[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]strcat av ns[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]entmod [b][color=BLUE]([/color][/b]subst [b][color=RED]([/color][/b]cons 1 nv[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]assoc 1 ad[b][color=RED])[/color][/b] ad[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]setq an [b][color=BLUE]([/color][/b]entnext an[b][color=BLUE])[/color][/b] ad [b][color=BLUE]([/color][/b]entget an[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entupd en[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]ssdel en ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Edited July 28, 2011 by David Bethel Fixed attribute loop value Quote Link to comment Share on other sites More sharing options...
harilalmn Posted July 28, 2011 Author Share Posted July 28, 2011 Thanks David.. That Worked...!!! Quote Link to comment Share on other sites More sharing options...
harilalmn Posted July 28, 2011 Author Share Posted July 28, 2011 David, By the way, how do I check if two strings are alike? In VBA we use the 'Like' operator... Say, If AttributeText Like "*(W1)" then what is it in Lisp? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 28, 2011 Share Posted July 28, 2011 David, I think that will change both attributes to the same value :wink: Quote Link to comment Share on other sites More sharing options...
harilalmn Posted July 28, 2011 Author Share Posted July 28, 2011 May be... In my case I just have only one attribute. So it worked.... Quote Link to comment Share on other sites More sharing options...
harilalmn Posted July 28, 2011 Author Share Posted July 28, 2011 But I am a starter in lisp. So I dont know how to iterate through the attributes. Well... David's code helped. Thanks for your suggestion.... RenderMan.... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 28, 2011 Share Posted July 28, 2011 Give this a try: (defun c:test ( / as el en i ss str typ ) (initget "Prefix Suffix") (setq typ (cond ((getkword "\nAdd Prefix or Suffix? [Prefix/Suffix] <Prefix>: ")) ("Prefix"))) (setq str (getstring t (strcat typ " to Add: "))) (if (setq ss (ssget '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength ss)) (setq en (ssname ss (setq i (1- i)))) (while (eq "ATTRIB" (cdr (assoc 0 (setq el (entget (setq en (entnext en))))))) (setq as (cdr (assoc 1 el))) (if (eq "Prefix" typ) (if (not (wcmatch as (strcat str "*"))) (entmod (subst (cons 1 (strcat str as)) (assoc 1 el) el)) ) (if (not (wcmatch as (strcat "*" str))) (entmod (subst (cons 1 (strcat as str)) (assoc 1 el) el)) ) ) ) ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
David Bethel Posted July 28, 2011 Share Posted July 28, 2011 David, I think that will change both attributes to the same value :wink: Lee is correct. I edited post #3 to reflect the correct code. Thanks! -David Quote Link to comment Share on other sites More sharing options...
Durf Posted September 24, 2013 Share Posted September 24, 2013 As a relative CAD newbie, with only "Google Training", I really have to thank guys like you for contributing and helping me out! You just saved me countless time with this solution. One would assume that adding .1 to numbers of wire labels in a set of drawings wouldn't need to be so difficult. You guys made it easy! Thanks again! Quote Link to comment Share on other sites More sharing options...
RickFlton Posted May 5, 2016 Share Posted May 5, 2016 Hi David I just tried your LSP and it worked great. Thanks for posting it. If you have the time would you mind explaining the processes in the your LSp. I am a bit of a novice but would like to know how each line worked. Obviously defun C;addstr is the command to run the file but the other commands including atype ns ss en ed an ad av nv. I understand down to teh "\nString to add: ")) I would certainly appreciate you comments and explaination. Thanks Regards Rick. Quote Link to comment Share on other sites More sharing options...
David Bethel Posted May 5, 2016 Share Posted May 5, 2016 (edited) Wow, It's been a while since I've commented a routine I have changed a bit on the format but it is basically the same, just a bit more efficient [color=#8b4513]; define a function named addstr[/color] [color=#8b4513]; the c: creates a command line call[/color] [color=#8b4513]; [b][color=BLACK]([/color][/b]/ local_variable_list[b][color=BLACK])[/color][/b][/color] [b][color=BLACK]([/color][/b]defun c:addstr [b][color=FUCHSIA]([/color][/b]/ atype ns ss en ed an ad av nv i[b][color=FUCHSIA])[/color][/b] [color=#8b4513]; initialize a [b][color=FUCHSIA]([/color][/b]getxxxx[b][color=FUCHSIA])[/color][/b] call[/color] [color=#8b4513]; if bit1 is set in [b][color=FUCHSIA]([/color][/b]getkword[b][color=FUCHSIA])[/color][/b], it forces an input of 1 of of the keywords[/color] [color=#8b4513]; [color=#2f4f4f]"Keyword List"[/color][/color] [b][color=FUCHSIA]([/color][/b]initget 1 [color=#2f4f4f]"Suffix Prefix"[/color][b][color=FUCHSIA])[/color][/b] [color=#8b4513]; Select the type of action needed[/color] [b][color=FUCHSIA]([/color][/b]setq atype [b][color=NAVY]([/color][/b]getkword [color=#2f4f4f]"\nAdd Suffix or Prefix [b][color=MAROON]([/color][/b]S/P[b][color=MAROON])[/color][/b]: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [color=#8b4513]; if bit 1 is set , this forces a non nil input[/color] [b][color=FUCHSIA]([/color][/b]initget 1[b][color=FUCHSIA])[/color][/b] [color=#8b4513]; get user input of NewString[/color] [color=#8b4513]; allow spaces , case sensitive[/color] [b][color=FUCHSIA]([/color][/b]setq ns [b][color=NAVY]([/color][/b]getstring t [color=#2f4f4f]"\nString To Add: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [color=#8b4513]; if user creates a SelectionSet of INSERTs with ATTRIButes[/color] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]0 . [color=#2f4f4f]"INSERT"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]66 . 1[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [color=#8b4513]; Initialize an integer counter[/color] [b][color=NAVY]([/color][/b]setq i 0[b][color=NAVY])[/color][/b] [color=#8b4513]; step thru the selection SS 1 EName at a time[/color] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [color=#8b4513]; retrieve the EntityDefinition[/color] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] [color=#8b4513]; retrieve the 1st Attribute eName[/color] an [b][color=GREEN]([/color][/b]entnext en[b][color=GREEN])[/color][/b] [color=#8b4513]; retrieve the 1st Attribute Definition[/color] ad [b][color=GREEN]([/color][/b]entget an[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [color=#8b4513]; step thru the INSERT definition and[/color] [color=#8b4513]; retrieve each attribute until a SEQEND entity is returned[/color] [b][color=MAROON]([/color][/b]while [b][color=GREEN]([/color][/b]/= [color=#2f4f4f]"SEQEND"[/color] [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 0 ad[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [color=#8b4513]; retrieve the current Attribute Value[/color] [b][color=GREEN]([/color][/b]setq av [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 1 ad[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [color=#8b4513]; concatenate the New Value[/color] nv [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]= atype [color=#2f4f4f]"Prefix"[/color][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]strcat ns av[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]strcat av ns[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [color=#8b4513]; modify the attribute entity definition with the new value[/color] [b][color=GREEN]([/color][/b]entmod [b][color=BLUE]([/color][/b]subst [b][color=RED]([/color][/b]cons 1 nv[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]assoc 1 ad[b][color=RED])[/color][/b] ad[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [color=#8b4513]; go to the next Attribute Name and Definition[/color] [b][color=GREEN]([/color][/b]setq an [b][color=BLUE]([/color][/b]entnext an[b][color=BLUE])[/color][/b] ad [b][color=BLUE]([/color][/b]entget an[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [color=#8b4513]; update the main insert Entity Name[/color] [b][color=MAROON]([/color][/b]entupd en[b][color=MAROON])[/color][/b] [color=#8b4513]; increase the integer counter[/color] [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]1+ i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [color=#8b4513]; exit the routine cleanly[/color] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] Have fun -David Edited May 5, 2016 by David Bethel Quote Link to comment Share on other sites More sharing options...
samehhosny Posted August 24, 2017 Share Posted August 24, 2017 Hi, I believe that threat is old but I found it very helpful. That lisp routine is exactly what I need except one missing piece. The block I need to edit has multiple attributes while I need to append a suffix only to values of single attribute out of all these attributes in the same block. I'm not an expert enough in list routines. So, if it's possible to explain to me how to modify that routine to modify only one attribute value in the block it would be great. Thanks in advance. Sameh Saad Quote Link to comment Share on other sites More sharing options...
steno Posted August 25, 2017 Share Posted August 25, 2017 Hi David, what am I supposed to change in your routine in order to add a prefix to a specific attribute of a specific block ? I also have to do this on multiple drawings (same block, same attribute). Any help would be greatly appreciated. Thank you, Ste Quote Link to comment Share on other sites More sharing options...
David Bethel Posted August 25, 2017 Share Posted August 25, 2017 Wow that is an older 1. For INSERTs with multiple ATTRIButes, filtering a TAGNAME is the easiest. You could also filter by the placement ( ie 1st 2nd 3rd 4th place ) in the order of ATTRIButes Then there also by text color, style, size, angle so on and so on What is your criteria ? But be fore warned, they are ways to that pretty much all of these can fail -David Quote Link to comment Share on other sites More sharing options...
steno Posted August 28, 2017 Share Posted August 28, 2017 I was thinking of: 1. Writing an AutoLisp routine that edits a specific attribute value of a specific block; 2. Writing a script that executes the routine; 3. Using Script-Pro in order to run the script on multiple drawings. Does this make any sense? Unfortunately I am a total newbie in AutoLisp Quote Link to comment Share on other sites More sharing options...
David Bethel Posted August 29, 2017 Share Posted August 29, 2017 I was thinking of: 1. Writing an AutoLisp routine that edits a specific attribute value of a specific block; 2. Writing a script that executes the routine; 3. Using Script-Pro in order to run the script on multiple drawings. Does this make any sense? Unfortunately I am a total newbie in AutoLisp Is that regardless of the tag name and/or attribute sequence ? Case sensitive ? -David Quote Link to comment Share on other sites More sharing options...
steno Posted August 29, 2017 Share Posted August 29, 2017 Actually every drawing has the same block in it (same block name, same tags). In this block there is an attribute whose tag name is "18". The routine should be able to add the prefix "0" to the value of this attribute. Thank you for your help David. Ste Quote Link to comment Share on other sites More sharing options...
Dark Templar Posted January 19, 2021 Share Posted January 19, 2021 On 7/28/2011 at 9:45 AM, Lee Mac said: David, I think that will change both attributes to the same value Hello, I am facing a similar task and would very much appreciate if you could help me with this code so it changes a selected attribute and not all of them. As long as we on subject I leave the information below that may be of interest. My Incremental Numbering Suite application will provide a far more extensive set of options to allow you to customise the numbering format, permitting a Prefix & Suffix, multiple incrementing sections, and alphanumerical incrementing. You can number existing attributed block references using this application by typing 'R' or 'r' at the AutoCAD command-line during object placement to enter Replacement Mode. My Incremental Array application will allow you to automatically increment the attribute values whilst arraying an attributed block reference (or other objects). Quote Link to comment Share on other sites More sharing options...
