guyzen2004 Posted October 9, 2008 Posted October 9, 2008 Is it possible to remove the arc symbol after you dimension an arc. Quote
soleary Posted October 9, 2008 Posted October 9, 2008 Is it possible to remove the arc symbol after you dimension an arc. Yes it is. Goto Dimension Styles. Make sure the dimension style on which the arc dimension was created is highlighted under 'styles' on the left hand side. click Modify (or Override if you just want to do it for specific cases). Click the Symbols and Arrows tab. Under Arc length Symbol Click None. Quote
guyzen2004 Posted October 10, 2008 Author Posted October 10, 2008 Thank you very much. Just upgraded to Autocad 2007 and found out that higher version can now dimension arc lenghts. Quote
soleary Posted October 10, 2008 Posted October 10, 2008 Thank you very much. Just upgraded to Autocad 2007 and found out that higher version can now dimension arc lenghts. You're welcome! Quote
