Greating a lisp to get a rectangle and impotting a block in it
Hi i would have another interresting question regarding the insertion on a block in a box .. it it possible to put in a dynamic block according a visibility name
  • Replies 27
  • CadFrank
    11
  • paulmcz
    7
  • Tharwat
    3
  • irneb
    2
Posted Images
I am out of this as I have no idea what is involved when it comes to dynamic blocks. Never had a chance to work with them.
Yes, if you're adept at Visual LISP.
Look into applying this:
(vlax-put-property [color=red]<VisibilityPropertyObject>[/color] 'vlaue [color=red]<VisibilityStateName>[/color])
... on the resulting DynamicBlockProperties Object when using the GetDynamicBlockProperties Method on the Block Object (
Edit: The value being applied to the must be included in the AllowedValues Property for the same Object.
You may need to use:
(vla-put-value [color=red]<DynamicBlockProperty>[/color]
 (vlax-make-variant [color=red]<VisibilityStateName>[/color] (vlax-variant-type (vla-get-value [color=red]<DynamicBlockProperty>[color=black])))
See here for a set of Dynamic Block Functions.
[/color][/color]
Perhaps I've misremembered (and misrepresented) supplying a String in lieu of a Variant for the value... It has been a while since I wrote the only routine I used for Dynamic Blocks??? :oops: If I have, then I apologize.
I'm trying to teach myself too much, purging information I've already learned (or so I thought!). :lol: LoL
Cheers! :beer:
I've always used the method shown without problem - no need to apologise Renderman.
Hey well i started to read my book but i don't think is fully adapted to autolisp. I can't see what the description of "vla" anywhere. I'm still trying to understand alot of thing for autolisp can't see to understand how to put all the script together. but i guess ill eventually figure it out.
But any how! should i intergrate the routine up there with the routine you gave me this morning?
So ill leave you on this and try to read up somemore to understand everything.
