just another question like that and i only want the answer no code if i would like for some dynamic blocks not to be count would they be a possible way of doing it even so they are in the drawing.
Yes, you could add both a filter for DXF group 2 (block name) to the ssget expression and an additional check for the effectivename property of the dynamic block when iterating through the SelectionSet (since dynamic blocks become anonymous when the visibility state is changed).
I could post an example if necessary.
Well im completly new at Lisp and im in the process of learning. what i really want is to learn those codes. So i can myself create a routine.
I will receive a book today on autolisp / visual lisp / vba so ill start my learning process with this i hope its a good book. but it's in french so im not sure you know the book
The book name is "Programmer autocad avec diesel" it is mostly sold in France i think since i can only find a library in Franec that has it. lol I live in Quebec Canada.
I was a hard book to find i couldn't find it in any librarie. Could only get it online.
so thank for the offer of the exemple i think ill start by learning the language then ill ask if i get lost
cheers
Wow, I've missed lots of posts :oops:... in short (as I run out of the office for lunch):
@ Lee - Your input & (polite! LoL) nitpicks are always welcomed :lol:... I've learned much from your hard work in the past, and as shown today, I continue to do so regularly.
@ CadFrank - I'm glad I was able to show you *some* of what's possible. I hope you find your book educational, and look forward to seeing your development initiatives soon. Good luck!
All, cheers! :beer:
  • 4 weeks later...
Hello,
the code not count the visibility state on this block.
@Lee Mac
make you a code with "count" and "dbcount"?
Hello,
Could you not attach the block using the forum's upload system? I'm hesitant to use other such sharing sites...
@Lee Mac
Do you mean modify my 'count' program to include 'dbcount'? Its possible, although I'm not sure how I would represent the count in the table...
the block: Zeichnung.dwg
yes - the 'count' program to include 'dbcount'.
With the new 'count' program I can count my block.
That would be great.
The program is reading the Lookup parameter instead of the Visibility parameter, but I do not know of a way to distinguish between a Lookup parameter and Visibility parameter as both have identical properties... :unsure:
Perhaps by including a check for known, Allowed Values?
But that requires knowing the list of Allowed Values for the Visibility Parameter for each and every block, which the user would have to add to the code manually...
Correct, the user would have to open the Dynamic block in the Block Editor, and make a list of each parameter once... you know, hypothetically speaking.
Yeah, ideally the program wouldn't need to be modified in any way :(
I can't really argue with that! LoL
So, Mexxx_ 'don't worry be happy' :rofl:
the code "dbcount" is ok - but not to my block.
I need
Visibility State...................Count
OT-Rauchmelder ZD......................1
but I get
0,0m...................................1
I need..
I know, see post #47 :wink:
Having finally figured out how to distinguish between the various parameters in a dynamic block, try this updated code:
[color=GREEN];;------------------=={ Dynamic Block Count }==---------------;;[/color]
[color=GREEN];;                                                            ;;[/color]
[color=GREEN];;  Counting all dynamic blocks by Visibility State.          ;;[/color]
[color=GREEN];;------------------------------------------------------------;;[/color]
[color=GREEN];;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;[/color]
([color=BLUE]defun[/color] c:dbcount ( [color=BLUE]/[/color] _Assoc++ _PadBetween lst ss vis vl )
   ([color=BLUE]defun[/color] _Assoc++ ( key alist )
           ([color=BLUE]lambda[/color] ( pair )
               ([color=BLUE]if[/color] pair
                   ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] key ([color=BLUE]1+[/color] ([color=BLUE]cdr[/color] pair))) pair alist)
                   ([color=BLUE]cons[/color]  ([color=BLUE]cons[/color] key 1) alist)
           ([color=BLUE]assoc[/color] key alist)
   ([color=BLUE]defun[/color] _PadBetween ( s1 s2 ch ln )
           ([color=BLUE]lambda[/color] ( a b c )
               ([color=BLUE]repeat[/color] ([color=BLUE]-[/color] ln ([color=BLUE]length[/color] b) ([color=BLUE]length[/color] c)) ([color=BLUE]setq[/color] c ([color=BLUE]cons[/color] a c)))
               ([color=BLUE]vl-list->string[/color] ([color=BLUE]append[/color] b c))
           ([color=BLUE]ascii[/color] ch)
           ([color=BLUE]vl-string->list[/color] s1)
           ([color=BLUE]vl-string->list[/color] s2)
   ([color=BLUE]if[/color] ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"INSERT"[/color]) ([color=BLUE]cons[/color] 410 ([color=BLUE]getvar[/color] 'CTAB))))
       ([color=BLUE]progn[/color]
           ([color=BLUE]vlax-for[/color] obj
               ([color=BLUE]setq[/color] ss
                   ([color=BLUE]vla-get-activeselectionset[/color]
                       ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))
                   ([color=BLUE]and[/color]
                       ([color=BLUE]eq[/color] [color=BLUE]:vlax-true[/color] ([color=BLUE]vla-get-isdynamicblock[/color] obj))
                       ([color=BLUE]setq[/color] vis
                               ([color=BLUE]cond[/color]
                                   (   ([color=BLUE]assoc[/color] ([color=BLUE]vla-get-effectivename[/color] obj) vl)   )
                                   (   ([color=BLUE]car[/color]
                                           ([color=BLUE]setq[/color] vl
                                                       (LM:GetVisibilityParameterName obj)
                                                   vl
                           ([color=BLUE]vl-some[/color]
                               ([color=BLUE]function[/color]
                                   ([color=BLUE]lambda[/color] ( prop )
                                       ([color=BLUE]if[/color] ([color=BLUE]eq[/color] vis ([color=BLUE]vla-get-propertyname[/color] prop))
                                           ([color=BLUE]vlax-get[/color] prop 'value)
                               ([color=BLUE]vlax-invoke[/color] obj 'getdynamicblockproperties)
                   ([color=BLUE]setq[/color] lst (_Assoc++ vis lst))
           ([color=BLUE]vla-delete[/color] ss)
           ([color=BLUE]princ[/color] (_PadBetween [color=MAROON]"\nVisibility State"[/color] [color=MAROON]"Count"[/color] [color=MAROON]"."[/color] 46))
           ([color=BLUE]princ[/color] (_PadBetween [color=MAROON]"\n"[/color] [color=MAROON]""[/color] [color=MAROON]"="[/color] 46))
           ([color=BLUE]foreach[/color] x ([color=BLUE]vl-sort[/color] lst '([color=BLUE]lambda[/color] ( a b ) ([color=BLUE]<[/color] ([color=BLUE]car[/color] a) ([color=BLUE]car[/color] b))))
               ([color=BLUE]princ[/color] (_PadBetween ([color=BLUE]strcat[/color] [color=MAROON]"\n"[/color] ([color=BLUE]car[/color] x)) ([color=BLUE]itoa[/color] ([color=BLUE]cdr[/color] x)) [color=MAROON]"."[/color] 46))
           ([color=BLUE]textpage[/color])
   ([color=BLUE]princ[/color])
[color=GREEN];;-----------=={ Get Visibility Parameter Name }==------------;;[/color]
[color=GREEN];;  Returns the name of the Visibility Parameter of a         ;;[/color]
[color=GREEN];;  Dynamic Block (if present).                               ;;[/color]
[color=GREEN];;  Arguments:                                                ;;[/color]
[color=GREEN];;  block  -  VLA (Dynamic) Block Reference Object            ;;[/color]
[color=GREEN];;  Returns:  Name of Visibility Parameter, else nil          ;;[/color]
([color=BLUE]defun[/color] LM:GetVisibilityParameterName ( block [color=BLUE]/[/color] visib )
           ([color=BLUE]vlax-property-available-p[/color] block 'effectivename)
           ([color=BLUE]setq[/color] block
               ([color=BLUE]vla-item[/color]
                   ([color=BLUE]vla-get-blocks[/color] ([color=BLUE]vla-get-document[/color] block))
                   ([color=BLUE]vla-get-effectivename[/color] block)
           ([color=BLUE]eq[/color] [color=BLUE]:vlax-true[/color] ([color=BLUE]vla-get-isdynamicblock[/color] block))
           ([color=BLUE]eq[/color] [color=BLUE]:vlax-true[/color] ([color=BLUE]vla-get-hasextensiondictionary[/color] block))
           ([color=BLUE]setq[/color] visib
                                   ([color=BLUE]=[/color] 360 ([color=BLUE]car[/color] pair))
                                   ([color=BLUE]eq[/color] [color=MAROON]"BLOCKVISIBILITYPARAMETER"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]entget[/color] ([color=BLUE]cdr[/color] pair)))))
                   ([color=BLUE]dictsearch[/color]
                       ([color=BLUE]vlax-vla-object->ename[/color] ([color=BLUE]vla-getextensiondictionary[/color] block))
                       [color=MAROON]"ACAD_ENHANCEDBLOCK"[/color]
       ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 301 ([color=BLUE]entget[/color] visib)))
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
Hey all,
Lee that seems to work just fine to me ...
But what if 2 or 3 blocks have the same visibilitystatename???
maybe, blockname + visibilitystate in overview?
greetz JOhn
not native enghlis
Lee - you are the best!!!!!!!!!!!!!!!!!!!!!!!!
for you new code "count";)
Thanks :beer:
We'll see :wink:
  • 6 years later...
Hi Lee...
This is a good one and more useful for my job.
Really appreciate...
I have a request you that "can we add a selection option in order to select a specific area including the dynamic blocks within a drawing" ????
Presently this command is taking whole the drawing.
I mean instead an entire drawing selection can we select part areas from the drawing??
Thanks in advance...:D:D:D
I just used this for the first time this morning, and while the default option is for ALL, you can also select specific areas of your drawing, instead of accepting the default.
Don't hit enter until you have selected the areas you want.
Did you download the latest version of this code, as shown in Post #55, or on Lee's website?
Thanks Lee, you're the best! :beer:
