aaryan Posted July 22, 2011 Posted July 22, 2011 Hi All, My colleague found this code somewhere on the net to convert lat long to UTM in WGS84 datum. I am not an expert in writing AutoLISP but I tried and used this code and wrote routine to be worked with and convert a single coordinate (20.10° Lat(N) and 71.10° Long(E) to UTM, it works well the answer i got is (X:719569.724) (Y:2223930.682). But when i checked the same coordinate with other converters like Trimble and many on online, the answer is (X: 719569.731) (Y: 2223930.631). I actually want to fix this error but dont know how? Can anyone please help me out and tell me what am i missing? Below is the lisp routine i have made using the code. Sorry for the poor english. Thanks in Advance to all of You. (Defun C:DD2UTM () (setq yval (getreal "\n Enter Lat Decimal Degrees: ")) (setq xval (getreal "\n Enter Long Decimal Degrees: ")) (setq UTM nil) (setq statA 6378137.0) (setq statB 6356752.3142) (setq statF 0.00335281066474748) (setq statIF 298.257223563) (setq statRM 6367435.68) (setq statK0 0.9996) (setq statE 0.081819190928906) (setq statE2 0.006739497) (setq statN 0.00167922) (setq ConstA0 6367449.14580084) (setq ConstB0 16038.4295531591) (setq ConstC0 16.8326133343344) (setq ConstD0 0.0219844042737573) (setq ConstE0 0.000312705217950448) (setq Sin1 0.00000484813681109536) (setq ConstE1SQ 0.006739496756587) (setq Zone (fix (+ 31 (/ xval 6)))) (setq ZoneCM (- (* 6 Zone) 183)) (setq DeltaLon (/ (* (- xval ZoneCM) 3600) 10000)) (setq LatRad (/ (* yval 3.141592654) 180)) (setq LongRad (/ (* xval 3.141592654) 180)) (Setq Curve1 (/ (* statA (- 1 (* statE statE))) (/ (expt (- 1 (expt (* statE (Sin LatRad)) 2)) 2) (sqrt (- 1 (expt (* statE (Sin LatRad)) 2))) ) ) ) (setq Curve2 (/ statA (sqrt (- 1 (expt (* statE (Sin LatRad)) 2))))) (setq MeridArc (- (+ (* ConstA0 LatRad) (* ConstC0 (sin (* LatRad 4))) (* ConstE0 (sin (* LatRad )) ) (+ (* ConstB0 (sin (* LatRad 2))) (* ConstD0 (sin (* LatRad 6))) ) ) ) (setq K1 (* MeridArc statK0)) (setq K2 (* Curve2 (sin LatRad) (cos LatRad) (expt Sin1 2) statK0 (/ 100000000 2) ) ) (setq K3 (* (/ (* (expt Sin1 4) Curve2 (sin LatRad) (expt (cos LatRad) 3)) 24 ) (+ (- 5 (expt (/ (sin LatRad) (cos LatRad)) 2)) (* 9 ConstE1SQ (expt (cos LatRad) 2)) (* 4 (expt ConstE1SQ 2) (expt (cos LatRad) 4)) ) statK0 10000000000000000 ) ) (setq K4 (* Curve2 (cos LatRad) Sin1 statK0 10000)) (setq K5 (* (expt (* Sin1 (cos LatRad)) 3) (/ Curve2 6) (+ (- 1 (expt (/ (sin LatRad) (cos LatRad)) 2)) (* ConstE1SQ (expt (cos LatRad) 2)) ) statK0 1000000000000 ) ) (setq RawNorth (+ K1 (* K2 DeltaLon DeltaLon) (* K3 (expt DeltaLon 4))) ) (if (< RawNorth 0) (Setq Northing (+ 10000000 RawNorth)) (Setq Northing RawNorth) ) (setq Easting (+ 500000 (+ (* K4 DeltaLon) (* K5 (expt DeltaLon 3))))) (setq UTM (list Easting Northing)) (setq utmx (rtos Easting 2 3)) (setq utmy (rtos Northing 2 3)) (princ (strcat "\n X:" utmx "\n Y:" utmy)) (princ (strcat "\n zone:" (itoa zone) "\n CM:" (rtos zonecm 2 0) ) ) (princ) ) Quote
lzucco Posted February 1, 2019 Posted February 1, 2019 (edited) Take a look at this https://www.cadstudio.cz/geocode https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/return-x-and-y-coordinates-from-lat-long/td-p/8153321 Edited February 1, 2019 by lzucco Quote
LUIZ CARLOS M. TAVARES Posted March 9, 2021 Posted March 9, 2021 (* ConstC0 (sin (* LatRad 4))) (* ConstE0 (sin (* LatRad )) would you tell us what number cames after last LatRad in this expression because it was not writed in you routine, but without it , this program not work well 1 Quote
