Hi Guys,
I am writing a program for adding scale lists in AutoCAD 2010.
This is where I am;
(defun AddMetersScales()
 	(command "-SCALELISTEDIT"  "ADD" "1:5000 (Meters)" "0.2:1" "Exit")
(command "-SCALELISTEDIT"  "ADD" "1:3000 (Meters)" "0.3333:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:2000 (Meters)" "0.5:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:1000 (Meters)" "1:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:500 (Meters)" "2:1 " "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:400 (Meters)" "2.5:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:300 (Meters)" "3.333:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:250 (Meters)" "4:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:200 (Meters)" "5:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:150 (Meters)" "6.6666:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:100 (Meters)" "10:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:50 (Meters)" "20:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:25 (Meters)" "40:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:20 (Meters)" "50:1" "EXIT")
(command "-SCALELISTEDIT"  "ADD" "1:5 (Meters)" "200:1" "EXIT")
Problem is that, if a drawing already has a scale in the above list, it brakes the loop and shows error.
How to handle this? I just want to skip adding that scale if the error happens...
Please help...
Actually, the above code is a part of a long one which is here;
;; The code below is copied from http://forums.augi.com/showthread.php?p=1045033 posted by mgonzales.224492 on 2010-02-11, 02:30 PM
;; Utilities to clean-up scale lists
;; Command to remove all XREF scale lists
(defun ScaleListRemXRef (/)
 (princ
   (strcat "\n"
    (itoa (DelScaleListMatch "*XREF*" (GetScaleListEntities)))
    " XREF scales deleted."
   ) ;_ end of strcat
 ) ;_ end of princ
) ;_ end of defun
;; Command to remove all Imperial scales
(defun ScaleListRemImperial (/)
 (princ
   (strcat "\n"
    (itoa (DelScaleListMatch "*=*" (GetScaleListEntities)))
    " Imperial scales deleted."
   ) ;_ end of strcat
 ) ;_ end of princ
) ;_ end of defun
;; Command to remove all Metric Scales
(defun ScaleListRemMetric (/)
 (princ
   (strcat "\n"
    (itoa (DelScaleListMatch "*:*" (GetScaleListEntities)))
    " Metric scales deleted."
   ) ;_ end of strcat
 ) ;_ end of princ
) ;_ end of defun
;; Command to ensure Imperial scales are present
(defun ScaleListImperial (/)
 (princ (strcat "\n" (itoa (InstallScaleList StdImplScaleList)) " scales added"))
) ;_ end of defun
;; Command to ensure ISO scales are present
(defun ScaleListMetric (/)
 (princ (strcat "\n" (itoa (InstallScaleList StdISOScaleList)) " scales added"))
) ;_ end of defun
;; Command to remove incorrect scales & ensure standard scales
;; in relation to the MEASUREMENT sysvar
(defun ScaleListStandard (/)
 (princ "\nRemoving XREF scales ...")
 (ScaleListRemXRef);Remove XREF scales
 (if (= 0 (getvar "MEASUREMENT"))
     (prompt "\nRemoving Metric scales ...")
     (ScaleListRemMetric)
     (prompt "\nInstalling Standard Imperial scales ...")
     (ScaleListImperial)
     (prompt "\nRemoving Imperial scales ...")
     (ScaleListRemImperial)
     (prompt "\nInstalling Standard Metric scales ...")
     (ScaleListMetric)
;; Utility functions
;; List of standard Imperial scales as per AutoCAD
(setq StdImplScaleList
      '(("1'-0\" = 1'-0\"" 12.0 . 12.0)
 ("6\" = 1'-0\"" 6.0 . 12.0)
 ("3\" = 1'-0\"" 3.0 . 12.0)
 ("1-1/2\" = 1'-0\"" 1.5 . 12.0)
 ("1\" = 1'-0\"" 1.0 . 12.0)
 ("3/4\" = 1'-0\"" 0.75 . 12.0)
 ("1/2\" = 1'-0\"" 0.5 . 12.0)
 ("3/8\" = 1'-0\"" 0.375 . 12.0)
 ("1/4\" = 1'-0\"" 0.25 . 12.0)
 ("3/16\" = 1'-0\"" 0.1875 . 12.0)
 ("1/8\" = 1'-0\"" 0.125 . 12.0)
 ("3/32\" = 1'-0\"" 0.09375 . 12.0)
 ("1/16\" = 1'-0\"" 0.0625 . 12.0)
 ("1/32\" = 1'-0\"" 0.03125 . 12.0)
 ("1/64\" = 1'-0\"" 0.015625 . 12.0)
 ("1/128\" = 1'-0\"" 0.0078125 . 2.0)
) ;_ end of setq
;; List of standard ISO scales (from ISO 13567)
(setq StdISOScaleList
      '(("1:1" 1.0 . 1.0)  ;Scale type A
 ("1:5" 1.0 . 5.0)  ;Scale type B
 ("1:10" 1.0 . 10.0)  ;Scale type C
 ("1:20" 1.0 . 20.0)  ;Scale type D
 ("1:50" 1.0 . 50.0)  ;Scale type E
 ("1:100" 1.0 . 100.0)  ;Scale type F
 ("1:200" 1.0 . 200.0)  ;Scale type G
 ("1:500" 1.0 . 500.0)  ;Scale type H
 ("1:1000" 1.0 . 1000.0) ;Scale type I
 ("1:2000" 1.0 . 2000.0) ;Scale type J
 ("1:5000" 1.0 . 5000.0) ;Scale type K
) ;_ end of setq
;; Function to obtain list of scale entity names
(defun GetScaleListEntities (/ lst item)
 (setq lst nil)
 (foreach item (dictsearch (namedobjdict) "ACAD_SCALELIST")
   (if (= 350 (car item))
     (setq lst (cons (cdr item) lst))
   ) ;_ end of if
 ) ;_ end of foreach
 lst
) ;_ end of defun
;; Function to obtain list of scale types in current drawing
(defun GetScaleList (/ lst lst1 item data)
 (setq lst  (GetScaleListEntities)
lst1 nil
 ) ;_ end of setq
 (foreach item lst
   (setq data (entget item))
   (setq lst1 (cons (vl-list* (cdr (assoc 300 data))
         (cdr (assoc 140 data))
         (cdr (assoc 141 data))
      ) ;_ end of vl-list*
      lst1
       ) ;_ end of cons
   ) ;_ end of setq
 ) ;_ end of foreach
 ;; Sort the list - most detailed to least
 (setq lst
 (vl-sort lst1
   '(lambda (s1 s2)
      (> (/ (cadr s1) (cddr s1)) (/ (cadr s2) (cddr s2)))
    ) ;_ end of lambda
 ) ;_ end of vl-sort
 ) ;_ end of setq
) ;_ end of defun
;; Function to delete scale matching a wildcard name
(defun DelScaleListMatch (pattern lst / item data count)
 (setq count 0)
 (foreach item lst
   (if (wcmatch (cdr (assoc 300 data)) pattern)
(entdel item)
(setq count (1+ count))
     ) ;_ end of progn
   ) ;_ end of if
 ) ;_ end of foreach
 count
) ;_ end of defun
;; Function to ensure list of scale are installed
(defun InstallScaleList (stdlst / lst item cmd)
 (setq lst (GetScaleList))  ;Get list of scale entity names
 ;; Remove items from stdlst which is already in the drawing
 (setq stdlst (vl-remove-if
  '(lambda (e) (/= nil (assoc (car e) lst)))
  stdlst
       ) ;_ end of vl-remove-if
 ) ;_ end of setq
 (setq cmd (getvar "CMDECHO"))
 (setvar "CMDECHO" 0)
 (command "._undo" "_Begin")
 ;; Start scalelist edit if needed
 (if (> (length stdlst) 0)
   (command ".-scalelistedit")
 ;; Step through remainder of stdlst
 (foreach item stdlst
   (command "_Add" (car item) (strcat (rtos (cadr item)) ":" (rtos (cddr item))))
 ) ;_ end of foreach
 ;; End scalelist edit if needed
   (command "_Exit")
 (command "._undo" "_End")
 (setvar "CMDECHO" cmd)
 (length stdlst)
;|«Visual LISP© Format Options»
(72 2 40 2 T "end of " 60 9 0 0 0 T T nil T)
;*** DO NOT add text below the comment! ***|;
;; The code above is copied from http://forums.augi.com/showthread.php?p=1045033 posted by mgonzales.224492 on 2010-02-11, 02:30 PM
(defun AddMeterscales()
(defun c:PurgeScales()
 (initget 1 "Yes No")
 (setq AddMtr (getkword "Add Standard Meter Scales? (Yes or No) "))
  (if
    (= AddMtr "Yes")
;If Yes
    	(AddMeterscales)
    	(Exit)
 (setq RemXRScales (getkword "Remove XRef Scales? (Yes or No) "))
  (if
    (= RemXRScales "Yes")
;If Yes
    (ScaleListRemXRef)
 (setq LdImp (getkword "Load Default Imperial Scales? (Yes or No) "))
  (if
    (= LdImp "Yes")
;If Yes
    (Progn
    	(ScaleListImperial)
  	(progn;If No
 			(setq LdMetric (getkword "Load Default Metric Scales? (Yes or No) "))
  		(if
    			(= LdMetric "Yes")
		;If Yes
    			(ScaleListMetric)
	);Progn If No
	  );Ends If
 );End Function
In the code above, When the scales are reset either to Imperial or Metric, it removes the scales already used by objects.
How do we fix it?
