open drawing using lisp
kalai
FWIW - Just be aware that when you change document namespaces (using vla-activate...) your code will stop working, unless your code is run from a separate namespace (outside of the ActiveDocument prior to vla-activate...).
HTH
HTH
Yes , I used to load my routines too much directly from the Vlide and when I run the vla-open with vla-activate , I can not do anything except shutting down the Vlide
and released that the document it self keep on loading for a while .
Thanks.
this is the code i could get
(defun c:old (/ cd vgad vgao vgd)
 (vl-load-com)
 (setq vgao (vlax-get-acad-object))
 (setq vgad (vla-get-activedocument vgao))
 (setq vgd (vla-get-documents vgao))
 (setq cd "D:/YBI/Drawing/Layout/global/Master/YBI.dwg")
 (if
   (= 0 (getvar "SDI"))
   (vla-activate (vla-open vgd cd))                               ; if sdi = 0
   (vla-sendcommand vgad (strcat "(command \"_open\")\n" cd "\n")); if sdi = 1
   )                              ; if
But i doesnot end.
now the drawing is opened.but i am not able to work.
i am getting fatal errror
could anyone help
Try it this way .
(defun c:old nil
 (vl-load-com)
 (if
    (vla-activate
      (vla-open (vla-get-documents (vlax-get-acad-object))
                "D:\\YBI\\Drawing\\Layout\\global\\Master\\YBI.dwg"
                :vlax-false
Tharwat
  • 10 months later...
Lee,
I have a question about your code, so I copied it here:
;;------------------------=={ Open }==------------------------;;
;;  Uses the 'Open' method of the Shell Object to open the    ;;
;;  specified file or folder.                                 ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  target - file, folder or ShellSpecialFolderConstants enum ;;
;;  Returns:  T if successful, else nil                       ;;
(defun LM:Open ( target / shell result )
   (if
       (and
           (or
               (eq 'INT (type target))
               (setq target (findfile target))
           (setq shell (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
           (setq result (vl-catch-all-apply 'vlax-invoke (list shell 'open target)))
           (vlax-release-object shell)
           (not (vl-catch-all-error-p result))
(vl-load-com)
As I understand, the active drawing after the line including:
will be the opened file, so the following lines:
can't be done, for forgetting shell and result values.
..., or I am wrong?
Ahankhah,
As I am new to this method of open a drawing also (I typically use the Document's Collection + Activate Method), if I understand correctly, Lee is employing the Shell.Application Object to open the drawing outside of AutoCAD (think double click in Windows Explorer), which allows for the code to release the Object within the Document that called. This code itself is quite brilliant in that way.
I am still attempting to determine if I am able to properly use this methodology, as we have 3+ version years (and vertical/non-vertical flavors of each) installed at any given time.
HTH
