ironman Posted July 15, 2011 Posted July 15, 2011 Is this possible? Can an object move through an animation while its gizmo stays stationary, so the map assigned to it looks as if its moving across it? Am I describing this accurately? Is it possible to "disconnect" the gizmo from the object, so the map stays anchored as the object moves around? Quote
Raudel Solis Posted July 16, 2011 Posted July 16, 2011 you want the material to stay in 1 place? if this is the case apply a uvw map and play with the rollout it has. Quote
Cad64 Posted July 16, 2011 Posted July 16, 2011 I think you're going to have to create an animated texture. Search Youtube. There are lots of videos on this subject. Quote
